SS wheels on a 2wd S10
You should probably go over to this forum:
http://www.s10forum.com/forum/wheels-tires-and-brakes/
These guys have installed just about every combo of wheels/tires on trucks...stock, raised and lowered.
should be 2" spacers... i know those wheels fit correctly on 4WD S10's(which are 58" wide (i think)... and the 2wd rears are 54.5" wide, so 4" divided by two= 2"
you should be able to use anywhere from 1.5" to 2.5" thats why i would go with 2"... right in the middle
You don't just get any type spacer but a machined adapter if going over a 1/2" for sure. The best bolt pattern to go to is the 5x4-3/4" then all the knock off Vette wheels in almost any size width for cheap. I am using these guys to make a adapter to put Z06 18x10" on my 6 lug SSTB. Do it right.
http://www.skulte.com/index.php/cPat...5fd265a726147b
Wheels
http://www.factoryreproductions.com/...vette&wheel=11
Wheels
Grave digging. Need some help. Can anyone tell me what wheel spacers i will need for my 02 s10 2wd base model, stock height, in order to put the american racing torq thrust i got off my brothers 00 trans am. The wheels are 17x9 with 45 offset and the tires are 245/45/17. The fronts dont fit, didnt try the rear, but the front the hub didnt fit inside the wheel. So i cam tell i need some kind of spacers
