Where to relocate Coils?
Old 02-04-2008, 04:13 PM
Ravenous T\A's Avatar
Default Where to relocate Coils?
Where do U think would be the best place to put a set of Truck coils on a 70 Camaro????(besides the valve covers) What Do I need to do to make this happen?
Old 02-05-2008, 10:32 AM
V8Rumble's Avatar
I've been thinking about doing this as well, so here's a 'bump' for ya.
Old 02-05-2008, 02:48 PM
philntx's Avatar
Since you omitted a picture showing the engine compartment, there is no way to guess what you already have mounted (or plan to mount) on the Firewall and/or the fender/tire wells.
Pic's help.
Old 02-05-2008, 03:04 PM
bczee's Avatar
I have seen that the YearOne Camaro has them between the head and the firewall. If you have enough room, that would put them out of the way..
But not knowing what your engine bay looks like and what your opjective is.. hard to make a recommendation. I guess almost anywhere would put them in a cooler place than on top of the valve covers.. Firewall/Fenders, etc
Old 02-05-2008, 03:43 PM
anybody mount them on the front member (K member or something like that?) Plus what wires do U use? Can U use make to custom wire set or do truck coils have different plug-in for the coils? Plus do you need the brackets for the coils to act as a ground or are they only there for mounting to valve cover? And why do some farts hurt and others dont?
Old 02-05-2008, 03:51 PM
V8Rumble's Avatar
I sure as heck wouldn't mount coils to a part of the suspension like the K-member - I'd be concerned that they'd be subject to a lot of vibration. At least on the "sheetmetal" parts (firewall, inner fenders) the vibrations have had a chance to be more dispersed/attenuated...
Not even gonna speculate on the other questions...
Old 02-05-2008, 03:55 PM
72chevelle6.0's Avatar
I had thought about mountung the one for my chevelle in the cowl.
Old 02-05-2008, 07:53 PM
S10xGN's Avatar
... Plus what wires do U use? Can U use make to custom wire set or do truck coils have different plug-in for the coils? ...
I need this info too, what type of boot is needed for each end and is there a universal "cut to fit" kit available?
TIA!
Russ
Old 02-06-2008, 08:05 AM
LS1MCSS's Avatar
I mounted mine on each inner fender. The relocation kits are easy to make. I used some tube I have thats just slightly larger than 1/4" ID for the spacers and 1/4" all thread rod hold it all together. The brackets are stainless steel pieces that I already had at home.
Old 02-06-2008, 10:07 PM
flywheel's Avatar
That sure looks good,,ls1mcss. much better than sitting on the VC's...Think I'll try that on my 71 chevelle.... Nice VC's.....
Rick
Old 02-06-2008, 11:36 PM
TT402LS1's Avatar
Heres how I did mine. (on the engine crossmember)
Ron
Quick Reply: Where to relocate Coils?
