reset odometer?
Old 03-16-2008, 10:26 PM
dudeman's Avatar
Default reset odometer?
i am doing an lsx swap into an 89 mustang and i plan on using the stock cluster from a camaro. does anyone know if there is a way to reset to odometer back to 00000?
Old 03-16-2008, 10:29 PM
Rhino's Avatar
If I recall correctly this has to be done by someone with access to a TechII. You'll probably be limited to dealerships. If they would do it, I'm sure it would be rather expensive.
Old 03-16-2008, 10:36 PM
dudeman's Avatar
is it something that one of the techs could do "on the side"? i know some people that know some people that know some people!!!
Old 03-16-2008, 11:13 PM
01WS6/tamu's Avatar
I dont think so. When we program a new cluster we enter the mileage via tech II and the odometer goes from there forward. I think it's a one time deal. I can try it on my truck at work tomorrow and see if it will let me.
Old 03-16-2008, 11:17 PM
dudeman's Avatar
could you just enter 0 for the milage though? i would defiantly appreciate anything you can find out!!!!
Old 03-16-2008, 11:27 PM
EnfuegoZ28's Avatar
You should be able to set the odometer to any mileage you want. Only dealerships have the computer to do it though. Person at work said he was havin problems with his oil pressure gauge in his S-10. Took it to a Chevy dealer to work on it. They put a new cluster in it, he got it back and it had 10,000 more miles on it. Took it back and they had the correct mileage on it and the gauge cluster back in it in 30 minutes. So I'm sure if you can find someone to do it, it can be changed to 0.
Old 03-16-2008, 11:29 PM
dudeman's Avatar
that is outstanding!!!!
Old 03-16-2008, 11:43 PM
EnfuegoZ28's Avatar
The hard part is finding somebody that knows somebody that knows somebody that can hook you up. Good luck!
Old 03-16-2008, 11:44 PM
dudeman's Avatar
i will find out tomorrow if i can get someone to do it!!!!
Old 03-17-2008, 01:04 AM
bczee's Avatar
Resetting the Odometer.. could be illegal... suggest you check your local DMV laws..
I know when used car dealer that reset them back and if found doing it.. get a very heavy finds...
Old 03-17-2008, 10:15 AM
Rhino's Avatar
Find (or ask around) on local F-body or other Chevrolet clubs/forums. There are a few guys I know locally that would do it cheap. If you don't live in a larger Metro area, it may be difficult to find.
As was stated, keep in mind that this could be potentially illegal. Most cars are mileage exempt due to age (anything older than 10 years), although you could be held liable for fraud if you tried to pass the car off as a lower mileage. If I were to use the F-body gauge cluster in my Swap I would more than likely reset the odometer as well. The car will be well over 75% new, and the engine / trans will have been gone through. In my eyes it's "new." If I were to use aftermarket Autometer gauges they would start off at 0 as well. Realistically, what's the difference?
Old 03-17-2008, 01:56 PM
philntx's Avatar
For the most part, you are just required to place an odometer reset label in the door jam or glove box that shows the date and the actual mileage. Like bczee said, verify with your local DMV
A picture of the dash with the actual miles and date wouldn't hurt either.
It will show up eventually in a carfax report if you ever take it in for service, collision, sell it. etc
It becomes illegal if you try to misrepresent the vehicle as having less miles than actual.
Old 03-17-2008, 03:07 PM
Kamin's Avatar
as far as i know you can NOT reset a cluster.
you can only set mileage on a brand new cluster, and only do it ONCE.
Old 03-17-2008, 03:13 PM
slow's Avatar
you cannot reset a cluster with a tech 2
Ryan
Old 03-17-2008, 07:03 PM
dudeman's Avatar
its an f-body cluster in a foxbody. i dont think i will be able to pass it off as factory!
Old 03-17-2008, 07:14 PM
Jhankinson's Avatar
an odometer can be reset....but I dont know ANY dealers who can do it. They all have to have incredible amounts of proof of actual mileage....almost a damn DNA test to prove its your car. Then they have to mail it to GM itself to get it done. I know a guy who is the service manager for a local dealership. He siaid its impossible to reset a used one at a dealer. Only new ones can be ONE time programmed from the factory. As in the case of a warranty repair or something on a cluster.
Old 03-17-2008, 07:31 PM
dudeman's Avatar
this isnt looking good!
Old 03-17-2008, 07:59 PM
cherryelky305's Avatar
is it possible to roll it over? maybe some program that inputs 400 MPH and then just give it a few hours to hit 99999999 just a thought.
Old 03-17-2008, 08:06 PM
Gun5's Avatar
if you have a cable and laptop you can do it... seen it done before forget what program
Old 03-17-2008, 09:18 PM
01WS6/tamu's Avatar
My tech 2 will only allow setup of a new unprogrammed cluster. Using the tis 2000 all modules genuine gm programming suite. Verified on my personal vehicle.2002 sonoma
Quick Reply: reset odometer?
