would love some input diagnosing ticking engine
put about a 60k mile used 2000 LS1 in the car, before I put it in I put in a small cam, new comp springs, moly push rods (7.4") and a set of LS6 heads that had been milled just to true them up.
Engine has been running fine, I didn't touch the oil pump so I think the O-ring is ok, on a cold start it runs about 50psi of oil pressure, when warm it idles about 30-40 (tough to tell on this gauge) and I'm running mobil 1 5w30
I can't locate the tick, it sounds like it's from the front but definitely doesn't sound off to one side or another.
it's louder under load and quieter when you're coasting but still there
it's not any louder or quiter with engine temperature that I can tell (like warm engine/cold engine)
it's probably not a header leak, I torqed those down again tonight.
it's definitely not a loose rocker, I torqued those again tonight too, all tightI don't think it's a lack of oil in the valvetrain, there wasn't a flood of oil in there but each rocker was oiled so I don't think it's a plugged passage or anything
I haven't torqued the spark plugs again in case I had a leak there, they wer pretty tight when I installed them though..
I haven't checked to be 100% sure the rods are the right length but this cam is so small I just kind of figured stock length would be ok, could be wrong I guess.
on the off chance it was just a sticky lifter I put in some seafoam last weekend, it's been about 100 miles and no change, I'll give it about 300 and change the oil
I didn't think until now to pull the rods and check for a bent one I should have done that.
any other ideas before I go crazy? I'm so paranoid it's something in the bottom end
LS1TECH & Trucks Sponsor
How loud is the tick? Does it sound like a sewing machine?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
I don't know how to answer that, louder than a sewing machine, loud enough I can hear it inside the cabin at highway speed.
I know with noises it's real hard to diagnose on the interweb
it has an LS7 clutch from you guys on it, that's working great
it's hard to locate where the noise is, but sounds like front of the engine, like around the water pump. It's not really fast, which makes me hope it's the top end.
tell you what, I'll try to get a vid of it tonight and see if you can hear the ticking on the video.
was also thinking I should pull the belts off to eliminate noise in the accessories and test run it a few seconds.
http://www.n2s1.net/RacingVideos/havoc_enginesound.wmv
and it doesn't sound like that at all.
it's like a taptaptaptap noise
