Steering Column HELP!! CHEVY II aftermarket front
Old 05-24-2008, 11:11 AM
AlmostfastLT1's Avatar
Default Steering Column HELP!! CHEVY II aftermarket front
I have a 63 chevy II with the checkered racing front end. I install an ls1 and t56... Now I order the flamning river column with tilt etc... FLA-FR20005 from summit racing... I have 2 universal joints that came with the checkered kit and I need to know what brackets I need to secure this properly... I know a couple of people have used this steering column with the aftermarket front clips but I can't find the posts...
btw the joints I have are 3/4 X3/4" smooth and the other is 3/4 X 9/16spline, but coming out of the steering column its 1"DD ???
Thanks Mark Tisdale
Old 05-24-2008, 11:57 AM
chevy2ls1's Avatar
Default Steering Coulmn Help
HI MAN I HAVE A 66 CHEVY 2 WITH THAT SAME FRONT END AND I USED AN IDIDOT COLUMN AND FLAMING RIVER JOINTS AND STAINLESS SHAFT. MY COLUMN HAD A 1"DD SHAFT AND I JUST GOT A 1"DD TO 3/4"DD JOINT AND USED 3/4"DD STAINLESS SHAFT. I DIDNT USE THE CHEAP JOINTS THEY SEND WITH THE FORNT END. INSTEAD I BOUGHT THE GOOD FLAMING RIVER STAINLESS JOINTS. I WAS TOLD THAT THOSE CHEAP JOINTS WOULD BIND UP WHEN YOUR CAR WAS TURNING TIGHT.
Old 05-24-2008, 03:34 PM
Dude your engine bay is clean my man and not over done!! Yea the flamning river and ididit are basically the same... what brackets do you use to mount the column.. any part numbers.
Old 05-24-2008, 03:37 PM
btw, did you have to measure and cut your steering shaft...???
are those the TCI LT headers
Old 05-24-2008, 05:37 PM
chevy2ls1's Avatar
I Built A Bracket For The Lower Column Mount. Then Once I Got That In Place I Measured From Joint To Joint And Then Cut The Shaft To Lenth. I Didnt Write Down Any Part#s For The Joints. Sorry Hope That Info Helps
Old 05-24-2008, 05:46 PM
I ended up finding the shaft and the joints on summit thanks... But, what about for the upper mount under the dash...
Old 05-24-2008, 09:52 PM
SUPERBOOST's Avatar
Default headers
chevy2ls1,what kind of headers are on your car and where did you get them?They look like nice longtubes.
Old 05-28-2008, 02:28 PM
Tttt!!!!!
Old 05-28-2008, 02:30 PM
Tttt!!!!
Old 05-30-2008, 02:22 PM
BBPanel's Avatar
I've just mocked mine up using the stock under-dash clamp - not sure why I'd change it for the final fit. Haven't fabb'd anything up for the firewall mount yet.
Old 05-30-2008, 02:27 PM
BBPanel's Avatar
Do you have a p/n for the upper radiator hose you used? What about the lower - any pics of it? Thanks. -Bob
Old 05-30-2008, 05:27 PM
my car ended up not coming with the column and etc. with the sale...
Old 05-30-2008, 09:40 PM
BBPanel's Avatar
I didn't know there was a steering column option or did you mean when you bought the car? - I bought a FR column.
Old 06-01-2008, 02:08 PM
Yea, I mean when I bought the car it didn't come with a steering column...
Quick Reply: Steering Column HELP!! CHEVY II aftermarket front
