Started my LS1 swapped 240sx today for the first time v.videos
Old 06-19-2008, 12:17 PM
IHeartTurbo's Avatar
Default Started my LS1 swapped 240sx today for the first time v.videos
http://www.youtube.com/watch?v=kSwqPsq3Pic
http://www.youtube.com/watch?v=qyhTdvZOe40
the old dude is my dad
Old 06-19-2008, 01:00 PM
93formto98T/A's Avatar
nice, now get her on the road!
Old 06-19-2008, 02:57 PM
bustac's Avatar
sweeet, are you using a factory harness, ecm, bcm?
Old 06-19-2008, 03:22 PM
Eddie 70's Avatar
Sweet stuff. I can't wait to shoot this video for mine. The first start was a little bit hard. Have you had a computer on it yet to tune any of the codes, VATS or anything out of it yet? Are you using the stock style throttle cable or FBW?
Old 06-19-2008, 04:35 PM
SirWarrior's Avatar
damn I'm so jealous right now!!!!
this thing sounds awesome.
Old 06-19-2008, 05:24 PM
rockytopper's Avatar
Congrats.
Just make sure you have oil pressure. Mine started right up only to find out the next day when I put the gauge on it I had zero pressure. After pulling the engine out 2 more times I finally fixed the problem. Apparently the ls1 has issues priming the pump if they have been sitting for extended periods.
Old 06-19-2008, 05:43 PM
00 Freak's Avatar
Originally Posted by rockytopper
Congrats.
So do what do u do when u have to prime it? Sorry i'm a newb w/ this and my motor hasn't been started in a while and i was worried about something like this.
Old 06-19-2008, 06:01 PM
Spoolin's Avatar
I like it!!
Old 06-19-2008, 11:36 PM
wbwhiteboy's Avatar
NICE! i love my swap! Just wait till you get it out on the streets! Mines just a 5.3 but its still hella fun!
Old 06-20-2008, 06:11 AM
Pop N Wood's Avatar
If you search around on this site, you will see some guys pull an oil galley plug and pressure feed oil into the engine.
Other guys say just take the spark plugs out and crank it over for a minute or two until oil is visible in the rockers.
Nice sounding motor. I should have started mine a month or two ago, but just can't find time to finish it off.
Old 06-20-2008, 09:34 AM
factory harness modified by myself, pcm tuned by jesse bubb at wait4me performance
Old 06-20-2008, 09:35 AM
i sent the pcm out to wait4me performance and had them remove all the codes, vats, etc and do a slight performance tune. im using the original ls1 throttle body and the 240sx throttle cable with a bracket i fabbed up.
Old 06-20-2008, 09:36 AM
Congrats.
yeah, unfortunately i couldnt find a cheap electric oil pressure gauge locally so i dont know for sure what the oil pressure was, but there was oil at the top of the engine. but everything has to come back out for paint and ill have a real oil pressure gauge hooked up before starting it again.
Old 06-20-2008, 12:54 PM
vaughn4's Avatar
sounds good. can you post up more info on what mounts, subframe, etc you used. cant wait to see more progress on this.
Old 06-20-2008, 12:59 PM
mounts i built, xmember i modified/built
i did everything myself except the pcm tuning
Old 06-20-2008, 09:53 PM
SirWarrior's Avatar
pics of those?
what did you do for headers?
Old 06-20-2008, 11:11 PM
Originally Posted by SirWarrior
pics of those?
I don't have any pics of them because they aren't 100% done yet. I still need to clean up the welds and powdercoat. Then I'll take pics.
The manifolds/headers are heavily modified stock manifolds off a 99 vette. I cut the flange off, welded 1.75+ tube to new flanges cut to 2 3/8", welded that to the manifolds, cut the collector off, welded in part of a 2.5" j-pipe. No pics of them yet either.
Quick Reply: Started my LS1 swapped 240sx today for the first time v.videos
