Potential swap headers, might help someone...
Old 07-12-2008, 10:14 AM
S10xGN's Avatar
Default Potential swap headers, might help someone...
Hi All,
After a few months of sweating out headers for my Maverick swap, I finally took the plunge and bought a set of GM flanges (#12480130) and BBK-1569 headers. Flanges were $19 each from Hendrick Chevrolet, and the headers were $349 from Jeg's. The headers are for a 351W swap into a fox-body Mustang. Buying a set of engine swap headers from "pictures" is a hit or miss proposition, and I got really lucky on this one. If you have a tight engine compartment with R&P steering, these might work for you. BTW, the distance between the frame rails is 26" and there is about 3/4" per side on the headers.
Attached Thumbnails Potential swap headers, might help someone...-100_0525.jpg   Potential swap headers, might help someone...-100_0526.jpg   Potential swap headers, might help someone...-100_0527.jpg   Potential swap headers, might help someone...-100_0535.jpg   Potential swap headers, might help someone...-100_0529.jpg
Old 07-12-2008, 11:18 AM
oange ss's Avatar
nice find !!! good job !!!!!
Old 07-12-2008, 03:06 PM
Eddie 70's Avatar
I would say you just got lucky on that one. Great find and nice work.
Old 07-12-2008, 08:39 PM
Novas Forever's Avatar
Very nice and good work. What did you use to get the tubing at the ports round again?
Old 07-12-2008, 09:35 PM
S10xGN's Avatar
Just a flattened pipe nipple, I would recommend getting a longer one and removing the threads though, the insides of the pipes are chewed up a bit... Put the nipple in a vise, then walk the (port) tubing around the nipple. It'll still need a bit of hammer forming.
Russ
Attached Thumbnails Potential swap headers, might help someone...-100_0537.jpg
Old 07-12-2008, 09:38 PM
V8Rumble's Avatar
Cool
Outstanding info man, you get a BIG in my book!
Old 08-16-2008, 07:47 PM
Monza355's Avatar
any pics of the passenger side and underneath/groung clearence?
Thanks,
Old 08-16-2008, 08:09 PM
S10xGN's Avatar
Thanks,
Certainly!
Russ
Attached Thumbnails Potential swap headers, might help someone...-100_0538s.jpg   Potential swap headers, might help someone...-100_0510s.jpg   Potential swap headers, might help someone...-100_0511s.jpg   Potential swap headers, might help someone...-100_0513s.jpg   Potential swap headers, might help someone...-100_0514s.jpg
Old 09-06-2008, 02:34 PM
cutlass_455's Avatar
Wow, killer work man. Nice clearance, and nicely tucked under there too.
Old 09-06-2008, 07:57 PM
magic's Avatar
Thats awesome! I wonder if something like this would work in an SN95 Mustang??
Old 09-07-2008, 12:48 AM
Hibs's Avatar
nice. i know i've seen people mention they went this route when doing an LSx in a fox body, you make it look plain simple! not to mention cheap! I just can't justify spending $600-$700 on a set of KooKs swap headers!
Old 09-08-2008, 08:45 AM
69 Ghost's Avatar
Boy I like that. I am looking at options for a first gen Camaro LSX swap. I find it hard to justify a $700 price tag for a set of headers no matter how beautiful.
Old 09-08-2008, 07:54 PM
magic's Avatar
Same here! The money saved can go towards a cam upgrade!
Old 09-08-2008, 08:05 PM
Tommy69z's Avatar
I'm thinking of cutting up my SB hooker super comps, since the most I can probably get is $100 for them. I just can't see them being as high as they are!
Old 11-22-2012, 02:45 PM
Capown's Avatar
Well since you were awesome enough to post on my thread ill post on this one to bring it back to life!
Did you simply cut the flange from the headers on the back side of the flange and follow it across? Also what size pipe is that?
thanks again for pointing me in the right direction happy Thanksgiving!
Old 11-22-2012, 03:23 PM
bczee's Avatar
Ghost, you can do the same, just use some BBC headers for you first gen...
IIRC, other have already done it. The BBC header tube should match up well.
BC
Old 11-22-2012, 08:34 PM
LS1 pwrd NOVA's Avatar
Maybe this is what I need to do for my 1st gen swap using big block headers.
Old 11-22-2012, 09:36 PM
S10xGN's Avatar
I used a porta-band along the front side and lopped of the flange along with the 3/8" or so tubing that was inside the flange. These were 1 3/4" tubes.
BC
The BBC's might work, but it won't be easy. They are on 4.84" bore centers as opposed to 4.4" for the LS motors. The tubes will need to be heated and warped into position.
Quick Reply: Potential swap headers, might help someone...
