ls1 rx7: cranks but doesn't start
Old 07-24-2008, 09:41 AM
slamdawg543's Avatar
Default ls1 rx7: cranks but doesn't start
The car is a 93 rx7 with a 99 trans am ls1
THe car cranks and the fuel pump is coming on. I have fuel pressure to the rails but there is no spark, injectors arent firing, and no tach signal.
-The crank sensor (brand new) and cam sensor are plugged in.
-all grounds are good: block, chassis, harness, and ecu.
-all fuses are good
-power is getting to the injectors and coils, but the ecu isn't telling them to fire.
any help is appreciated...
Old 07-24-2008, 01:39 PM
digitalsolo's Avatar
Is your PCM running? Do you have someone with a scanner that can plug into your OBDII port and check if it can see the PCM?
Do you have power during crank? Their are some leads on the RX7 chassis that have power in accessory and run, but not during cranking. You wouldn't be the first to plug a PCM into one of those.
If the PCM can be reached, and the power stays on during cranking, you need to check continuity on you crank sensor wires. The car should fire without the cam sensor, so that shouldn't be your issue.
If all else fails recheck your grounds a few more times. They're sneaky little wires...
Hope that helps a bit.
Old 07-24-2008, 01:47 PM
pcm is running, the scanner can read codes, only code is a coolant voltage high/low, or something. i ran the switched power directly to the battery for temporary purposes to try to start it. still nothing.
i am getting 12v out of one of the crank sensor wires, 0.0v out of the middle and 0.3v out of the other end wire, while key is in on position
I'll go over the grounds again, all help is appreciated. thank you.
Old 07-24-2008, 01:58 PM
lowerthanyou00's Avatar
ummm vats? did you delete it?
Old 07-24-2008, 03:26 PM
bczee's Avatar
Even with the VAT not deleted.. it would start and run for a few seconds.. so... if it is not starting, it is more or something else than the VATS. But Yes, you should check to make sure it is diabled anyway.
Old 07-24-2008, 04:13 PM
no i dont have vats disabled, but as stated, it would start and then shut off...
Old 07-24-2008, 08:18 PM
Skele4door's Avatar
Check to make sure you have power going to all of your orange and pink wires. I'd bet you forgot to send 12v to your injectors.
Old 07-25-2008, 12:02 PM
How is your tach wired? I can see RPM on my tach while cranking (1998 F-Body PCM). Do you see anything?
Somewhere on this forum is the instructions for testing a Crankshaft Position Sensor; I don't have the link handy right now though.
It almost has to be the crankshaft position sensor, as you verified you have both power at the coils, and no spark from the coils. If you have power at the coils, and the PCM tries to start the car, you should be seeing spark even if the injectors weren't wired correctly. No CPS and it can't tell when to fire spark.
Have you ohmed out the wires to the CPS from the PCM yet? That only takes a few minutes if you have a helper to hold a wire (and a voltmeter or test light). Make sure you unplug the PCM before you put 12 volts for a test light on those BTW (obviously).
Old 07-25-2008, 12:06 PM
ssduane's Avatar
Assuming you have power to pink and orange when in the run position, but do you have power when its in the crank position? This is where I originally goofed.
Old 07-31-2008, 08:09 PM
I have 12v going to the pink and orange wires to the coils and injectors, and power in crank position.
I'm not getting a tach signal at the tach, or in the data logging thru the 0bd2 port, nor a maf signal either
The crank sensor is brand new, and the ohms readings for the crank position sensor, are 12v, 8v, and 8v
another bit of info, is that when i crank the car, the voltage drops to .5v on the coils power
Old 07-31-2008, 08:12 PM
SatisTraction's Avatar
one of the crank sensor wires is a ground. so i would look into that more.
Old 08-03-2008, 09:28 AM
are you sure? on the ecu pinout it says the wires are one power wire, and 2 signal wires...
Old 08-03-2008, 09:52 AM
jomomma's Avatar
where is the pcm located at.reason im asking is i had the same problem initially before i mounted the pcm. it was sitting close to the motor and causing some kind of interference with the coils. as soon as i moved the pcm back it fired right up!
Old 08-04-2008, 10:01 AM
its inside, under the passenger footwell
Old 08-07-2008, 03:27 PM
ok, you are correct, the yellow/black wire coming from the crank sensor is a ground, but its not testing out as a ground. Would anyone know why its doing this?
Old 08-07-2008, 04:25 PM
also, i rechecked my switched power after checking the fuse block. it was cutting out during cranking. so now i have it back directly on the (+) terminal temporarily. I am now getting 10v to the coils during cranking... all other symptoms are still occuring
Old 08-07-2008, 04:54 PM
onefastrx7turbo's Avatar
make sure the battery is 100% or jump it while cranking from another car
Old 08-08-2008, 06:55 AM
LS1MCSS's Avatar
What is the fuel pressure while cranking?
Old 08-08-2008, 08:57 AM
i'll check and get back
i've had a jumper pack connected to the battery, and ive also had the battery on a charger over night. Its getting plenty of juice
Old 08-08-2008, 11:16 AM
Fuel pressure in 'key on' is 60psi, then continuously drops, even during cranking.
Quick Reply: ls1 rx7: cranks but doesn't start
