Glass seperating from fabric top!
Has anyone ever had this happen to them? I Did, was washing car and ever so gently went over the area below rear glass on top witha soft spunch and it seperated. Nothing is ripped andglass hasnt cracked or anything. I applied some glue i got from advanced, just went in and said whats the strongest shizzle u got. holding just fineright now, been about 2 weeks, even had a few highway runs and its holding, gonna clean-up the beed.
Heres my deal, i went to a local chevy steallership and they wanted to replace the whole fn" top, which i kinda expected, but then i talked to a private shop and they wanted to replace the glass for $550! I dont see how that would solve the problem! THe original glasss is fine, coulnt u just remove it and re-apply new adhesive? I mean thats the problem, the adhessive and not the glass or fabric. I think they just are so use to people just blindly sheeling out cash to replace the whole top all the time that they dont even attempt to repair them anymore. Any ideas of what i can do, cause im thinkin this is just a temporary fix for now!?thanx Darren
i had a 95 camaro that did same thing. pull it up first and look to see if any debri has gotten under it. there should be a strip under edge of the top.clean both places good.get some 3m 2 sided body moulding tape pull it tight and stick it to glass. heat it with a hair dryer and rub it while heating it.the heat makes it stick better. i now have a 97 with a white vinyl conv top and they say the vinyl shrinks and it does not line up with glass so i have to get the whole window. i also have white vinyl perforated interior. nobody but hawks 3rd gen has the covers and they have to be custom made.
I heard it is just factory glued on to start. ?
Everyone on here that is having issues just glues it back. I too have been told to replace it by a place that does convertible tops. Screw that. I'll use glue.
happened to me aswell, the window just fell off lol , i cut a similar piece of fabric , glued the window on it , and then glued it back on the top.. I done this as a temp. fix but its been that way for 4 years now , im just going to change the convertible top since its kind of discoloring anyway.. but glue seems to work pretty well
Yep. You will be chasing your tail until you replace the top. I have new tops on both of my verts. The new tops are aftermarket and hopefully more durable. I think the aftermarket tops use a better glue (I hope). If the interior is in excellent condition, it pays to get the top replaced to prevent any water damage to the rest of the car. But, if you can keep up with the glue applications, you might be able to keep your original top for a year or two. But, once the window drops completely, the game is over. BTW, I glued the top on my red vert several times even after the windo dropped out. After the glue, I ran a bead of clear silicone sealant. Good Luck!
My top sucks already. But I'm going to replace the entire top with one from a salvage yard that only deals with cars that have LSX engines.
Picking up a top that looks great, but the window is already loose!
I'll mess with glue for a while I guess. It's not a daily driver anyways.
Yup, me too. Good think my Z is a sunny day toy and lives in the garage. Glass is totally seperated. Called the Top Shop (local experts I trust) who said the glass comes from GM heat bonded to the curtain. New window comes with new curtain attached. Installed is $750. Ouch! I am going to try the 3M window weld route first. Beats the Gorilla Tape that is holding it on now. The replacement route is really the way to go, but I have other budgeting concerns! May have to do it anyway at some point.
Great! my drivers side corner on my has a lil rip by the glass. I bet thats only a time and matter before it drops!! Where you guys getting yours at!!!??? i need some names that i can trust!
Moderator
Lot of them come apart where the glass is glued, you can
get a tube of proper polyurethane adhesive at Advance
for about 20 bucks. Or black 3M marine adhesive at West
Marine. Take your time with surface prep.
I got my replacement top from an ebay user called hindsightseeing. It came with a video showing how to replace the top on a 4th Gen Firebird. I watched the video about 2 or 3 times before I started. You will need to buy or rent a small electric or air staple gun (electric ones are like $30 to buy from Lowes). Other than that, nothing special is needed. You will need some fabric adhesive (several mentioned in this thread), preferable in a spray can or something that you can spread on with a 1" brush. Set aside a weekend and do it yourself. It's not that hard.
And no, I do not have the video anymore. Someone else beat you to it.
