Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What Heads and Cam with Maggie?
Old 11-17-2008, 04:33 PM
mhoglund's Avatar
Default What Heads and Cam with Maggie?
2006 Corvette A6 build:
Magnacharger mp112
AFR 205's 65 cc OR Edelbrock Xtreme rpm 214's 65cc ?
Crane 1.8 roller rockers OR Yella Terra 1.8 shaft mount rockers?
Crane extreme duty springs and hardened pushrods
Yank 3200 stall converter
?? F/I Cam?? Which one?
As you can see I need some direction. My goal is 550 rwhp and 600 rwtq and a mid 10 second E.T. Does anyone know the difference between the Crane and Yella Terra rockers? The Crane roller rockers are almost double the cost of the Yella Terra shaft mounts and I would think the shaft mounts would make the valve train more stable. Also the Yella Terra's don't require the heads to be machined like the Crane shaft mount rockers.
Now for the cylinder heads. I'm sure everyone would agree AFR makes a great set of cylinder heads. I'm considering the 205's from AFR and the Edelbrock Xtreme rpm 214's. Both sets of heads are 65 cc. The edelbrock heads seem to be the most bang for the buck, however these heads are only machined in the critical areas. Is that going to make a big difference in the power?
I'm also looking for input on an aggressive F/I cam. I've had a few suggestions but the cams that were reccomended seemed to mild. EPP sounds like they have a good one, but I can't find it on their web site. I need some suggestions.
Old 11-18-2008, 10:55 AM
greentahoe's Avatar
I was always told overlap was bad on boosted engines
Old 11-18-2008, 08:00 PM
mhoglund's Avatar
I was always told that a low lobe seperation was bad for boost. (Ex 112 lsa.) What would be a good boost cam then? I'd like something around 232/240, .580-.600 lift with 1.8 rockers. Will AFR 205's make me lose boost? What heads would be best?
Old 11-19-2008, 10:27 AM
greentahoe's Avatar
You may be right, but the idea of valve overlap bleading boost makes sense to me. Check with the FI guys. I'm pretty sure overlap is not good. Anyway, yes you will see less boost with a better flowing setup,but you will also see more power. You'll have to swap pulleys to "see" the same boost number
Old 11-19-2008, 07:36 PM
N4cer's Avatar
There's no way that cam has 64* of overlap.
And for discussion's sake, people are getting great results from going with slightly bigger cams than previously accepted and getting great results from them.
Old 11-19-2008, 07:57 PM
SilveradoSS500's Avatar
Are you running the stock torque converter? I would think you should go alittle small for more torque unless you get a big stall.....
Old 11-20-2008, 11:19 AM
Ragtop 99's Avatar
Let's clear up the confusion. Overlap at .05 is just 2* and that is not an issue for FI. The 64* of overlap is at advertised duration of .004 or .006
With a maggie, I'm not sure why you're trying to squeeze low end TQ out of the heads. The constant displacement of the maggie pretty much does that for you with just a tiny bit of lag compared to a true NA car. I'd be inclined to leave the heads alone and maybe a little earlier IVC on your cam.
Old 11-22-2008, 01:41 PM
mhoglund's Avatar
This sounds stupid, but what is IVC?
Old 11-22-2008, 05:27 PM
WHPLASH's Avatar
This is the car I'd recommend for you. You can also do an LG FI cam. You'll need a high stall to pair up with it.
http://www.exoticperformanceplus.com....html?item=679
I don't care for the cam specs you have listed above. JMO
Old 11-22-2008, 07:46 PM
mhoglund's Avatar
Those specs are very close to the VHP 099 cam specs listed above. The only difference is the LSA of 115 campared to 117 and the lift is higher, however with the Crane 1.8 rockers the lift would be .589/.589 Whats the overlap on that EPP cam?
Old 11-23-2008, 08:54 AM
03blackZ06's Avatar
cam is fine. I would go with a higher lift and also the ars should be 72 cc to bring the comp ratio down a little to be safer with more boost.
Old 11-23-2008, 09:34 AM
Ragtop 99's Avatar
IVC = intake valve close. You don't mention the ICL (intake center line) so I can not determine the IVC from what you posted. However a 232 cam on a 117 LSA makes for a later IVC unless there is a lot of advance. The late IVC is good for top end power though.
Old 12-06-2008, 11:59 PM
mhoglund's Avatar
To The Top
Old 12-07-2008, 06:42 PM
mhoglund's Avatar
anyone else have any input?
Quick Reply: What Heads and Cam with Maggie?
