Why aren't the LS-3 Vettes faster than the LS-6 Vettes?
All I read everywhere is how impressive the LS-3 motor is. How much more torque it has, etc.
Yet, when I read about quarter mile times. The older LS-6 Vettes dip into the 11s at around 117 miles per hour while the LS-3s are said to run 12.5s at around 115.
What am I missing?
What am I missing?
the Z06 is considerably lighter than the LS3 vette. the LS3 vette weighs about 300 lbs more than the Z06 as well the Z06 is geared different i beleive. gears and 300 lbs diet alone will make the cars perform like you have seen.
i dont beleive i have ever seen a bone stock LS6 Z run anything less than high high 11's or deep low 12's.
Cars are about equal according to the fast list of each car at CF, and the ls3 is quicker once you start adding mods. The MN12 is a lower geared transmission in the Z, and it is lighter, but the cubes take over once the modding begins.
1 Post
They just had a new GrandSport Vert that ran 12.3 @ 115 on street tires W/ 2:73's and it is heavier than a C5 Z06.Nice Skylark,i would like to see some pics when there is a LS motor in there.
Coming soon. Right now I am doing the disc brake conversion, installing the new rear and trans. After the motor is all built and every part and detail is worked out, I will do the swap. I just love to drive the car, so I could never bear for it to sit torn apart for long.
The LS3 cars have runflats compared to the C5Z,
The GrandSport has Bigger/Heavier wheels/brake rotors compared to LS6
The torque managment is more agressive on the LS3 compared to LS6
The LS3 car is heavier than the LS6
Those are the sole reasons, because a Z51/GrandSport has the same gearing (M12) as the C5Z.
i know this isnt "factory stock" but its close enough, Ragner went 11.55@117 with drag radials and a cold air intake back in 2002
http://www.youtube.com/watch?v=1cWT4kZkYb8
The Ls3 is a lot faster. I've raced both and got smoked by an ls3 on the highway and beat an c5z at all speeds.
Ls3s with full exhaust/ CAI/ tune are running almost the same times as c6 z06s
So they arent really comparable. Like others said before the ls3 is hindered by a pretty bad factory tune/torque management and with minor bolt ons they get pretty dirty quick
http://forums.corvetteforum.com/c6-z...fast-list.html
here is the fastest C5z06 list
http://forums.corvetteforum.com/c5-z...fast-list.html
c6 fastest list
http://forums.corvetteforum.com/c6-t...lenge-225.html
This is from the famous "RANGER" and his times with his cars
'06 Z06 red 236 passes
Bone Stock Stock Tires……11.10 127.76 1.79 60'
Bone Stock DRs......….…….10.74 129.50 1.59 60'
'02 Z06 350 passes
Bone Stock Stock Tires……11.81 117.26 1.78 60'
w/ CAI & DRs………...........11.52 120.21 1.64 60'
