Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
post pics of your c5 fat tires and your specs
Old 01-16-2011, 01:37 PM
98goldiZ28's Avatar
Default post pics of your c5 fat tires and your specs
hey guys i currently bought 19x10 rear wheels for my vette and wanted to know how fat can i go?
im currently thinking on going with a 335 tire with out modding is it possible?
Old 01-17-2011, 11:08 PM
T-REZ's Avatar
ANYBODY i would like to hear also
Old 01-18-2011, 12:02 AM
one fast zo6's Avatar
305x30x19 FTW
Old 01-22-2011, 06:17 PM
98goldiZ28's Avatar
anybody got some fattys on their vettS?
Old 01-23-2011, 09:07 AM
Red99TA's Avatar
I doubt that a 335/30-19 or 335/35-19 tire would fit on a 10" wide rim but you'd have to check on that. I run a 305/35-18 on my stock 10.5" wide rims and I think that's about the widest you would want to go although I think some run 315's on their 10.5" wide rim too for what it's worth. A 335 is a bit wider than a 315 plus you're on a 10" vs a 10.5" rim.
Just did a quick search and it looks like you'd be good with 295's.
Old 01-23-2011, 04:03 PM
SCM_Crash's Avatar
No 335 will fit on a 10" rim without having a crap load of side wall to stretch. I would say that's unsafe as well. If you had a 16x10 wheel, that may be a different story.
The widest you can go on a 19x10" is 305 on some tires and 295 on others. You don't get a lot of side wall on a 19" wheel, so you're pretty screwed if you want wider tires.
A 19" 335 would need an 11.5" wide wheel.
Old 01-23-2011, 10:18 PM
V-seriesTech's Avatar
18x10.5 fronts, 295's...18x12.5 tears..335's
Old 01-27-2011, 02:02 PM
01bird58's Avatar
I am actually in the same boat as you and have been reading up about this. For a 10" rim a 285 will give you the best fitment. You can stretch it to a 295 or a 305 but you will be diminishing the purpose of the wide tire because it will begin to bubble up and wear out the tire unevenly (as I understand it). Now way in hell will a 335 fit, biggest a 10.5" rim can go safely is 315 I believe. Read up on the sticky in the wheel section for more info. Im debating it myself weather I want a 19x10 or a 18x10.5 and get a wider tire.
Old 01-30-2011, 08:36 AM
RamAirTA's Avatar
C6ZO6 Motorsports, 19x11x65mm offset, Nitto 325/30/19. Fit perfect with no rubbing on the inside and do not stick out at all. I'll try to get a pic later.
Old 02-04-2011, 05:58 PM
OKcruising's Avatar
335/30/18 rears. 315's in the front. I run 18x12's with a spacer in the back; different wheels will probably not stick out as much as mine do (~.75" each side)
Old 02-04-2011, 06:53 PM
old-
265 18 fronts-295 rears..
somewhat current shoes..295 18 fronts on a 18x10.5 and 12.5 x 18 with 33 rears..
cousins Z06..18x10 fronts with 265 fronts, 335 rears..18x12.5
my old wheels on a SW Z06...
The BLUE Z06 and my white NON Z06 car are both mini tubed and on coilovers FYI.
Old 02-04-2011, 11:49 PM
mikep2002's Avatar
Are you just looking for waxer tires or are you looking for traction?
Old 02-06-2011, 07:50 AM
VortechC5's Avatar
18x9.5 with 265/35-18 in front and 19x12 with 335/30-19 in the rear. the tires are Nitto NT05.
Old 02-07-2011, 04:23 PM
douniasg's Avatar
20x13 345/25/20 rears 19x10 285/30/19 front drag tires 18x13 345/35/18 m/t
009-1.jpg?t=1297116980
004-1.jpg?t=1297116980
007-1.jpg?t=1297116980
mini tubbed with modified bilstien shocks and leaf spring
Old 02-07-2011, 04:47 PM
WKMCD's Avatar
I ran 315x30x18 PS2's on 11.5 inch CCW Big Street Classics. They were flush with the fender and they would rub every now and then on the inner fender. I just noticed it when I had the tires off. I'm running 345x30x19 on 13 inch CCW 500's now. They are flush with the L5 flares and pretty tight to the inner fender.
Old 08-04-2011, 06:30 PM
porchrd's Avatar
Thumbs up spacer on rear rims
Hi:
I like the way your ZO6 is, it looks bicthin!!!!!!!!!!!
I have 2004 ZO6 and I bought Toyo R-1's 335/30 18's for the rear.
I am looking at 18 X 12 ZO6 aftermarket rims to mount these Toyos on.
You said you added a spacer to the rear of your rims!!! Is it a 1/2" 3/4"
or a 1". I would really appreciate any info you could assist me with.
You also mentioned that you have 315's on the front!!! 315/??? & what
size rim??? You have no clearance or turning problems with the 315's in the frontYour Z must really stick good to the corners for sure.
Years ago I had a 1969 427 (500+ H.P.) with Ansen Sprints 15 X 12's
all the way around ( I had to flare the fenders with L-88 fender flares but
even back then that car really hugged the corners.
I am new to this site and this is my 8th vette (ZO6) Love this body style even more than the C-6.
Well hope that you may find time to reply to the above!!!
Thanks
porchrd
bettersrichard@yahoo.com
Old 08-16-2011, 10:22 AM
ZSS2148's Avatar
335/30 and 345/30 don't give the correct overall diameter And look like balloons IMO.
355/25 on a 19X13. Leaves you with the stock overall diameter and a more proportional look.
Old 08-26-2011, 11:33 PM
meine96ws6's Avatar
Wow! Your car looks sick...
Old 08-27-2011, 08:12 AM
OneBadZ0Sick's Avatar
Old 08-27-2011, 11:45 AM
LSOHOLIC's Avatar
Share some details on the wheel and tire setup....offset, backspace, mini-tub ??
Thanks.....and some better pics of the tire protruding past the fender...
Quick Reply: post pics of your c5 fat tires and your specs
