What automatic tranny can hold a lot of power??
Yes, if you want an overdirve auto that's the one to get out of a late model 3500 truck. It is basically a th400 with an extra gear. www.pro-touring.com look in the auto trans section it'll help alot. Andy
Talk to Carl Rossler, Extreme Automatics about building a trans, or the Vette Doctors about who builds their trannies. I believe EA and Rossler have built 4L60/65Es that're withstanding near 1000rwhp. The 80E will definatly handle the power, but Im not 100% as to if it'll fit under the C5...should and may take some BFH work and a 12 pack, but it should fit.
The c5 auto is capable of 450 ft lbs of torque to the wheels,anything more and your pushing your luck.
The 8 second LPE twin turbo c5 1000hp has a beefed auto tranny.
FLP can build you anything.Just bring your wallet.
Probably the 80e. That tranny is pretty much a th400 with an over drive. Another option is a TH400 with a gear vendors. That would give you 6 spd auto cause you have the half gear in 1, 2, and 3.
I dont think it was the 80E, I think it was a built 65E by Rossler in the TT 427 anyway. I know there's been some other major HP LPE cars that've been converted to auto's that I believe have used 60/65Es. I think Major Spray on the forum also has a built 65E aswell, but Im not sure by who.
This is from FLP...
Machine pump body and cover to insure true and flat faces
Set pump rotor and slide clearance to .0015-.002 thousandths
High output pump slide spring
Billet aluminum boost valve in pump
Install hardened stator shaft in pump cover
FLP hi-pro friction 2-4 band with solid lining
8-Borg/Warner .078 hi energy frictions with koleen steels 3-4 clutch
Borg/Warner 29 element forward sprag
Borg/Warner 4L65E low roller clutch
FLP heavy duty sun shell with bearing
FLP extreme duty input housing with steel sleeve pressed around input shaft splines with machined overun piston to increase strength
New Borg Warner clutches
New bushings
New GM internal wiring harness
New GM solenoids
New GM pressure manifold switch
New seals, gaskets, and filter
Install Transgo HD-2 performance shift kit with 2 washers
Transgo vacuum mod kit
Corvette servo
Aluminum 1-2 and forward accumulator piston upgrade replaces plastic pistons
Prep case for vacuum fitting and debur case of flashing
Set end play to performance specifications
Our Level 5 4L65E is our most powerful electronic overdrive transmission we offer. When you have a all out power application but still want to keep the driveability of overdrive look no further than our Level 5 transmission. This transmission has been used in a number of high horsepower NA and supercharger applications as well as a few turbos. One customer of ours has over 150 1/4 mile passes on his Level 5 trans and its running as good as the day we put it in. This on a car that is making 725 rwhp. We offer our Level 5 4L65E for LS1 and LT1 Fbodies, C5 Corvettes, and LS1 based trucks. $2850
4L65E includes the above Level 4 parts with the addition of:
GM 5 pinion planet assemblies front and rear
GM reaction shaft with bearing
FLP's extreme duty sun shell with bearing which is stronger than GM's 4L65E shell
Cryogenic treated input shaft, output shaft, & reaction shaft
New bushings
New GM solenoids
Corvette servo
Rossler built stage 2 A4 here in my 97'
Over 8K hard miles and 50+ 1/4 mile passes....good as new.
I have talked to Carl R....his refreshening for $545 sounds good if I ever need it!
That 4l80E will not fit without MAJOR<MAJOR modifications and you are stuck with a beefed up 4L65E and CHuck Johnson at FLP builds one of the best and is probably the most popular choice for BEEFED up A4 trannys on the forum and his customer service is GREAT and he stands behind his PRODUCT big time and is a SUPER NICE GUY!!. Give him a call and tell him i said "HEY". Carl Rossler also has a fine reputation but BRING A BIG CHECK BOOK if you go that route!!!!!!!!!!!!
Originally Posted by VINCE
How much power going thru your setup and what is the price of the Rossler?
$3500+ but it came with the car when I got it
I suggest you call FLP & Rossler and decide that way. I have been to FLP and they have a good setup as well but I think Carl has been doing them and a few others longer.....http://www.rosslertrans.com/
$2850 for a tranny that can hold 725rwhp is pretty awesome.. I plan to make more than that. I wonder if it can hold..
Originally Posted by NOSjohn
damn, i'm in the wrong bid'ness.
