Whats The Best Clutch?
STOCK CLUTCH DID NOT HOLD UP TO SOME MODS AND 315 BFG DR'S BURNED IT FIRST PASS! SO MY ? IS WHATS THE BEST FOR A C5 VETTE? LET ME KNOW WHAT YOU GUYS THINK SURE WOULD LIKE TO RUN BETTER THAN A 13.18
King of the radial tires
I got 150-175 DR passes per C5Z06 clutch.
You probably just glazed yours on that pass by too much slip on the launch. When the clutch cools, it's gnerally fine again.
But I'd suggest you start doing the standard maintenance on your clutch fluid.
Ranger
Ranger
Ranger
Ranger
sorry but the z06 clutch is crap. doesnt take the abuse for long, and will eventually start to "stick"
maintenance? hard to bleed the system without doing a clutch swap pretty much!
i ran the SPEC 3+ for a while, which wasnt that bad. now im using the RAM HD, and im more than happy with it! seems to take the abuse very well, and the clutch/flywheel kit VERY reasonably priced.
Ranger
Ranger
I agree with Ranger. I ran two years with LT's and Dr's at 3-5 runs per week on my stock clutch. Anyways I am about to order a Spec 5 once I find a good price.
Don't get the SPEC brand man. We had two corvettes that were both totaled due to pressure plates coming apart, at high RPM.
Highly recommend anyone BUT them.
I'd try RMS....EXEDY....RAM....etc etc.
how were those cars totaled? just curious.......kind of a scary thought too
The amount of damage, exceeds the total value of the worth of the car.
For example...my car, had 18,000 dollars in parts alone on my car. Not even labor is included in that. The other car, still hasn't been totaled yet but,...we'll see. The exact same damage that was inflicted on my car, was done on the other. There identical in damage.
Scary? I guess. No time to be scared, you have no warning. Just BOOM. and hope that your able to get the car to a stop. Then after you stop it...make sure you don't have a fire from all the severed lines......like my buddies car did.
Some foul ****.
I ran a Mcleod in my fromula for quite some time. By far the best clutch I have ever driven on the street and the track. Once the nitrous hits the FRC I plan on using the mcleod again.
Chris
Chris
Originally Posted by ram-it
I have the LS7 clutch and love it!
Have you made any passes with the LS7 clutch yet?
If so, what kind of launch rpm did the clutch take and have you had any pedal issues yet?
The C6Z owners have found the LS7 clutch to be quite flakey on launch above 3500. The pedal hangs and the clutch glazes. Surprising, because the LS6 clutch was much more robust at normal power levels.
So I'm interested in your experience with the LS7 clutch.
Ranger
If you have clutch pedal issue with a stock LUK clutch, then you might want to start the maintenance routine on the fluid in the clutch hydraulics.
With that in mind, here are three clutch fluid issue threads to review:
Clutch Pedal Woes--Fluid Impact
C6Z06 Clutch Hydraulic Fluid--the Chevy Spec
Clutch Pedal Woes--Fluid Changing Kit
Ranger
1 Post
Exedy Twin
Originally Posted by marlowchris
Check into the Aussie clutch or RPS. Lots of posts on them, do a search. Best 2 clutches on the market right now IMO. BTW I run an Exedy twin.
Doug aka allngn_c5
I have about 400 miles on the new ram twin disk with upgraded ceramic metalic pucks. It is a little graby on normal street driving but it seems to hold for now. We will se when I put 20-25 psi of boost to it. This clutch is rated at 1200 horses by ram.
