Question as to horsepower for ZO6 with mods!
I am curious as to what other Vette owners think it should make at the ground. I am in search of a Speedway White 2001 ZO6. I have decided to go with Longtubes,Halltech,ported TB,pulley,electric water pump,full roller rockers,T-REX cam,true 3" duals with no cats or mufflers,cutouts on each collector,PRC cnc'd heads,free mods, and after that a 150 shot of the juice. Any ideas as to what it might make?
Oh and BTW what do you plan on for the diff and clutch, I am going to keep the stockers untill my textralia setup comes in and then just start saving for 390's and hardened output shafts
reply
I am planning on running a Textralia clutch,4.10 gears and hardned shafts. I was alittle curious as if the water pump would be worth it. I am really hoping for around 425-430 all motor though.
jbusmc1986 I can't wait to see what your car makes. Let me know when you get it all done and dynoed.
no doubt dude... my nitrous came in yesterday and the rest of the parts are shipping today and tommorow... now I am in a frantic rush to find a ls6 intake and a textralia clutch.... I think that the clutch install will be right after the dyno bc I need to have this car on the road as much as possible... its my dd and I have no time to do 1k break in miles on the clutch before the dyno
ok.... not that big of a diff, but If you have the cash it is up to you... just make sure with someone mory numbers savy than myself that the ratios will be fine with the cam, because even with the same ratio the rollers open the valves alot quicker... same distance but much quicker
