Guestimate on 1/4 time
Car:
01 ZO6 402 ls2 stroker motor, livernios stg 3 heads, g5x-3 cam, lg headers, no cats and dumps,fast 90/90, built stg 4 rpm tranny, spec 5 clutch, built 3.42 rear, 250 shot of spray.
Tires will be a 26x10.5x16 M/T in the rear and a 195 front radial.
Will be launching the car at 4k rpm and slipping the clutch alittle. I know this is a bad way to judge but just want a guess on what it could possible run.
Thanks
Thanks
Fast...... really really fast..... I can only imagine, I would say around 800 hp so somewhere in the high 9's or low 10's if you get the traction... Big IF
it really depends on the driver. Lots of power and a bad driver = bad times.
With a good driver I'd say somewhere in the 10s. I don't know if that's enough tire to handle that much power (well maybe if you use the giggle gas after you get to going). But that is just my opinion.
Originally Posted by Assassin
must be nice living in fantasy land, I'll have to come visit some time I want a break from reality...
thread is usless w/out pics....
For pics its just a yellow 01 zo6, nothing special or crazy done to its outside, looks stock, under the hood is different story...
Needs some wiring cleaning up but you get the idea..
Car went 11.6 at 130 with a cam only and 150 shot. Rest of the car was stock on that pass with Drag radials
Originally Posted by LETHL_ZO6
High 9's/ low 10's should be easy if you can get it to hook. FWIW, I'd look into another cam for a 402.... your leaving a LOT left on the table with all those supporting mods.
