Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Old 05-03-2016, 11:37 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
Front Parking Light / Turn Indicator
Old 04-01-2007, 02:48 AM
Tim`'s Avatar
Default Front Parking Light / Turn Indicator
Guys: just recently my left turn signal indicator has started to flash as if a bulb was out. I checked and sure enough the front driver's side parking light / turn indicator below the headlights has gone out.
I can't figure out how to get to the bulb without taking off the front fender or removing the headlight. Does anyone know how to change these bulbs?
Also the driver's side headlamp is loose (shakes a little while I drive). Is there a mount that these rest on that can go bad or need tightening? The passenger side seems fine.
Thanks,
Tim
Old 04-01-2007, 09:33 AM
LS1Tech Co-Founder
Nine Ball's Avatar
I'm not too familiar with C5s, but I'll bet there is a flip-down panel underneath the front of the car (in front of the tire) that you need to unbolt to reach up inside. Need to get the car on some rhino ramps or jackstands to do this. Similar to the 98-02 Firebirds.
Old 04-03-2007, 01:17 PM
chuck01's Avatar
Default Bulb
I heard if you have small enough hands you can get at it by moving the brake duct in the front bumper.
Old 04-03-2007, 01:25 PM
chuck01's Avatar
Default Here you go.
Found on the Corvette Forum.
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Old 04-04-2007, 09:32 AM
LS1Tech Co-Founder
Nine Ball's Avatar
10 minute job.
For safety, you should also disconnect the battery with the headlights in the up position. It would suck to have something kick those on and shut on your hand.
Old 05-23-2007, 09:55 PM
Tim`'s Avatar
That's what I did, and it worked great. Took about 5 minutes per side
Old 05-23-2007, 10:03 PM
slpfirehawk's Avatar
Good luck. I took a look one day and said no way.
Old 05-23-2007, 10:41 PM
Jersey_TA's Avatar
I turned the headlights on, then backed the switch down to turn them off, but leave them up. Then I took off the hood bumper(or whatever that thing is with the nut and rubber piece next to the headlight). Make sure you remember to just break the nut loose and keep track of it's original position. After that I just reached in and changed the bulb.
Old 05-24-2007, 01:20 AM
chuck01's Avatar
Default Lights
Another cool tip is to change your bulbs from yellow to white, that way during the day your dlrs are white and look like fog lights. Also remember, when you turn your reg. lights on these dim.
Quick Reply: Front Parking Light / Turn Indicator
