Drag Rims for 02 corvette?
16 inch camaro rims for the rear will fit
you can use 2 gto spares for the front but you will have to replace the tires with a good high speed tire. ccw will sell you the tires to fit the gto rim.
you can buy the drag pack from ccw for $2400.00
best bang for the buck is get a set of vette frnts....The Z06 are best and lighter and you can put a ET street of BFG on them in the 315 series and hook up nicely....just have him watch the clutch and rearend.....
I now have a CCW Drag pack and that is an awesome setup to use. For the longest I did have the front Z06 wheels and they work great as well.
Originally Posted by Zturd
I use these, seem to work ok. Found them laying around and figured ehhh what the heck everyones doing it
[IMG][/IMG]
[IMG][/IMG]
Dumb Ass Vette Moderator
You can also do 15"/16" Weld or Bogart combos, but you need to put a rear calipers up front to clear the rims. I do not like this idea since the front calipers deliver the major of the stopping force.
The CCW package is well worth the $2400 price tag for them new. You can pick up a good used used from $1600 to $1800.
Keith
Originally Posted by goodtimes44
Are you sure the 16 inch camaro rim will fit? Ive ran the weld xp 16's and they barely cleared, I don't think there was a 1/4 inch gap. I was told these were the only 16's that would fit.
Keith
1-they are lighter
2-the fronts are skinnier
3-you can put a MT drag radial on the rears and have no problem hooking with reasonable power levels.
that is what I have for the strip on my car. Worked really good, not mention was nice and cheap.
