Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Torque Tube 0, SideStep 1
Old 08-18-2007, 11:34 AM
SideStep's Avatar
Default Torque Tube 0, SideStep 1
It was a real fight to get the Torque Tube out and the snap-ring is almost dangerous, but I won!!!
I am replacing MANY things before I install the supercharger and the TT bushings were on the list for this weekend.... Now for the sad news... The factory ones look perfect:crazy: :crazy: :crazy: Oh well, it was a character building experience
Old 08-18-2007, 12:50 PM
allngn_c5's Avatar
You know why it looks so good right ??? Read where its made (Made in Germany) LOL.
Are you going to upgrade the one end of your drive shaft now with a drive shaft power coupler ?? I think its made of Billet Aluminum. LG Motorsports sells them and I added one when I had them put in the Carbon Fiber Driveshaft. Good luck with your project. BTW glad to hear that it is Torque Tube 0 and SideStep 1 and not the other way around.
Old 08-18-2007, 12:53 PM
allngn_c5's Avatar
Since the TT is out, how does your clutch and flywheel look ?? Do what you can before you put it back together. Again good luck with your project and let us know how it turned out.
Old 08-19-2007, 12:34 PM
JoeyGC5's Avatar
Looks like it went fairly uneventful. I'm just finishing up Motor, trans, diff rebuild, and clutch swap all on jack stands Kinda sucks when doing it yourself
Old 08-19-2007, 02:16 PM
SideStep's Avatar
YES it does!!!
I am re-doing all the same... plus new wheel bearings/rotors and breaks on all four corners..
Old 08-19-2007, 04:57 PM
alwaysinboost's Avatar
good thing you are replacing the bushings now while everything is apart. I've had my driveline out four times so far this year and its going to be a fifth this weekend because my bushings are shot.
any tips on removing the TT? I saw you said the snap-ring was dangerious...
Old 08-19-2007, 05:53 PM
SideStep's Avatar
It is just VERY strong!!!
I used these from Harbor Freight... it was still a pain getting it out.
http://www.harborfreight.com/cpi/cta...emnumber=92374
Old 08-19-2007, 06:20 PM
pdd
pdd's Avatar
congrats
Old 08-19-2007, 08:11 PM
cool, I got a bunch of those plyers.
Old 08-19-2007, 08:59 PM
WKMCD's Avatar
Mine didn't look so good.
Old 08-20-2007, 08:33 AM
Dumb Ass Vette Moderator
ls1290's Avatar
LS1Tech 20 Year Member
At least now you know how to do it. With the SC installed you will have to do it again at some point in time.
Keith
Old 08-20-2007, 03:41 PM
marlowchris's Avatar
That snap ring is a major pain, removing and re-installing. Other than that is is a breeze.
Quick Reply: Torque Tube 0, SideStep 1
