Cam Only
Cam Only
Sick Speed Performance (1984camaroz28) built cam only z28 goes 11.3@121 with a 1.60 60ft time. The time i cut a 1.49 60ft I banged the revlimiter and both shifts and still ran an 11.4 @119. Not to mention it was about 75* i even got burnt lol. I think it has 10's in it if it will hook up launching 4k off of the brake.
Lets see i have shitty stock shocks in the rear. Ill go with qa1s. I only launched it at 2500 to cut a 1.49 60. It goes to 4200 on the brake. HMMMM just maybe i can cut another tenth like that. GENIOUS I SWARE !!! not to mention that the tires on the car are shot and there is some power left in the tune. Oh and it was run through a full exhaust no cutout.
just hate when people are like i could do this and then do this and can run 1/2 sec faster...just do it and run the times, no qustions there...not saying you cant bud i know the trex and 90/90 are plenty also i thought you were a stick...get the times the cold air is coming...
I still would like to know weight. I run the T-Rex too. M6 though and trap 119 and change at 3600+lbs. I have a stock intake and ported stock MAF and TB though. Best with that set-up is 11.48@119.47. I have switched to SD tune and the car feels stronger. I hope to have new numbers soon. That was on a 1.62 60'.
i would say 3400 lbs the weather that day was hurting me also. im gonna put it back on the dyno to get some more power out of it. I was only shifting it at 6800 that run i may try 7000 and bump the limiter up. What were u shifting at ?
This cam does not make power as high as people think. I shift mine about 6700. Mine stopped building power at about 6300, but I think the intake was limiting that a bit. In Any case, I do not see these building power above 6500. Holding power up to 6800 sure. You can try shifting at 7000 and see what she does.
I have a similiar setup with a trex. I weigh 2950 with me in it. Do you fiqure to get a 1.3 60 foot I would have to dump the clutch at 7000rpms? I guess I need to grow a set of nuts and give it a shot!
Good luck to you!
Good luck to you!
