1/8 mile with bolt ons. Good Enough??
Old 11-14-2008, 02:06 PM
fbirdserge00's Avatar
Default 1/8 mile with bolt ons. Good Enough??
Well went to Irwindale CA ran my 00 T/A with slp lid, 80 tb, bbk intake, hedman lt's no cats all the way back,2200 stall and tune. this is what i ran. Do you guys think this is good times?
1st run with M/T DR 17psi(stalled at 2000)
R/t .810
60' 1.942
330 5.571
1/8 8.488
mph 85.33
2nd run with M/T DR 17psi(stalled 2200)
R/t .727
60' 1.978
330 5.614
1/8 8.535
mph 84.96
What do you guys think. Im thinking of maybe thinking of throwing some 3.73's at it, because as im passing the finish line im barely shifting out of 3rd. NE feedback wil be appreciated. Thanx
Old 11-14-2008, 02:21 PM
PowershifterNC's Avatar
mph seems a bit low to me.
you def. don't want to be changing gears as you go thru the lights
what gear are you running now?tires?
Old 11-14-2008, 02:28 PM
Well im not changing the gear, its auto so i really dont have a choice. i usually leave it on drive. i got stock 3.23 gears, Mickey thompson drag radials. 9.5inch wide
Old 11-14-2008, 04:09 PM
99_ls1_z28's Avatar
You seem to be on the slow side. Look at my sig, I don't have a stall or a tune.
Im guessing you have a stock stall right?? What was the DA??
Old 11-14-2008, 04:58 PM
12secSS's Avatar
My wife was out there last night with my SS.
The DA according to her weather station was around 2000'. That stall is very much like stock, so you are close to your potential with it. If you upgrade to a 3200 stall (like a Vig3200 or a Yank 3200) you will see better results.
Old 11-15-2008, 07:59 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
George hit the nail on the head here. You're doing okay for the mods and DA, but if you want to go faster a higher stall would be next on the list. Also, try launching a little lower on rpm, as you want the converter to "flash" a little so the car will "launch" from the line instead of "pushing" from the line.
My Formula has a stock stall and a few bolt ons, and I've launched it anywhere from 800 rpm to 1400 rpm (most the stock stall would hold), and the 60 foots are better at 850-1000 rpm than higher.
Derek
Old 11-15-2008, 08:49 AM
thanks guys, so a higher stall it is. I appreciate all the feedback
Old 11-15-2008, 09:08 AM
cbra-klla's Avatar
air up those dr's too...run as much air in them as you can as long as you're still hooking
Old 11-15-2008, 04:03 PM
buzz12586's Avatar
Yea put a real stall in it and it should pick up a lot. The gf's car has gone 7.60s on a 1.58 60ft with a 3200Vig in it, full bolt ons.
Quick Reply: 1/8 mile with bolt ons. Good Enough??
