my results from 3600 and ram air
Old 12-18-2008, 08:22 AM
silverz28camaro's Avatar
Default my results from 3600 and ram air
well my setup is a 2000 z28 with the 224 cam, ls6 heads and all other bolt-ons, 3300 race weight.
i went 11.70 @ 117.10 1.70 60 best, many 11.8 runs with the 2800 fuddle and slp metal ram air scoop,
then i went with a vig. 3600
went 11.60 @ 116 1.59 60' and many many 11.6xx @ 115 runs with 1.60- 1.65 60's ( still on 245 nittos
then i made my own sux2bu ram air setup and the car went 11.64 @ 117.46 with a 1.70 60 spinning, then second and my last run was 11.56 @ 117.1 with a 1.64 60' again spinning
so i concluded that the stall definitely helped me all the way to the 1,000 feet, then slightly lost mph( et would be better with a better tire) and the top end i lost by the stall, i gained back even more then my best with the 2800 after the ram air.
I still had the factory maf and slp lid, i just swapped over to a 85mm maf and the fast toys lid, would be nice to get those results as well but the track closed. I did notice a gain in the 5,500 6,500 range on a test drive, but i don't have proof. next spring i will have my ls2 shortblock, new cam and fast 90/90 with ewp and another 70lbs off the car, so we will see what that gets me, hopefully a 10.9x. Oh and a better tire
Old 12-18-2008, 09:22 AM
BayAreaSS's Avatar
It's always nice to be able to go to the track and see your gains after each mod. Congrats!
Old 12-19-2008, 01:14 PM
98camaroLS1M6's Avatar
Obviously you still have more in it, with a set of mt drag radials, you should be in the high 1.5x 60', you make enough power and that stall will def. get you there.
Old 12-19-2008, 07:20 PM
well see next year!!!
Old 12-19-2008, 07:29 PM
firefighter813x's Avatar
that makes me want my old vig 3600 back. i downgraded to the vig 3200 for the dd. good run.
Old 12-19-2008, 07:35 PM
Restricted User
1BAD_LS1's Avatar
just got my vig 3600 today Im so excited to get it installed! I am on stock T/C right now so its gonna be one hell of a change! Glad to see you gained so much from it!
Old 12-19-2008, 08:57 PM
yeah, i went from the stock to a 2800 and thought i would never go back. and now i have my 3600 i will never go lower, i almost want a 4,000 but i do a few highway pulls with my m6 buddies and as of now i can feel the slippage. Thats why i have an ls2 going in that will take 7,000 so i can have more top end.
Old 12-19-2008, 08:59 PM
i don't think i would ever go lower than a 3600 again. with my 3.73 gear it took of normal from a stop well. not to much slippage at all. Do you think it was worth going lower, my car is my dd also, and i don't think the in town mileage was hurt more than 1mpg from my 2800.
Old 12-19-2008, 10:08 PM
jetlag's Avatar
Congrats, I love my 3600 stall
Old 12-19-2008, 11:09 PM
I see your times in your sig are pretty good, i was thinking about a 100 shot or so. First i want to be high 10's on a streetable motor. I'm trying to do everything i can to get the car light while still having a full interior and stock 16inch snowflake wheels. I still have about 70lbs i need to get off the car, anything over that will be big $$$, such as the lighter windsheild, a-arms, brakes, and a few other things i have in mind.
Old 12-20-2008, 07:35 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Congrats on the times, getting close to roll bar territory!
Derek
Old 12-20-2008, 08:21 AM
jetlag's Avatar
Derek
And then you get a rollbar and no longer need it cause of the added weight hahah
Old 12-20-2008, 08:29 AM
Restricted User
2001 Pewter WS6's Avatar
I used to drive my TCI 4400 with 4.11 gears on the street and had no issues. With the steeper gear, it made the bigger stall more streetable.
Old 12-22-2008, 10:00 AM
wlsmoku's Avatar
was the DA and wind the same each time you went out?
Quick Reply: my results from 3600 and ram air
