Stock LQ9 longblock+PT88=10.07@128
Old 04-29-2009, 11:07 PM
Restricted User
98Z28CobraKiller's Avatar
Default Stock LQ9 longblock+PT88=10.07@128
Video Added
http://s115.photobucket.com/albums/n...BIRVids032.flv
I achieved my goal for this phase of the project.
Went to the track tonight. Had the boost setup exactly the same (13lbs for most of the pass creeping up to about 15lbs). Pulled one degree of timing down to 13*. Turned the 2 step up to 3900 (about 9 lbs)and put the MT DR's on.
1st Pass
60'............1.432
330'............4.197
1/8.............6.475
MPH.........108.09
1000...........8.431
1/4......;....10.100
MPH.........130.24
2nd Pass (lost the slip from memory)
60'............1.46
330'...........
1/8.............6.46
MPH.........107.5
1000..........
1/4......;....10.11
MPH.........127.xx
3rd Pass
60'............1.417
330'............4.166
1/8.............6.437
MPH.........108.08
1000...........8.395
1/4......;....10.071
MPH.........128.31
Old 04-30-2009, 10:13 AM
transdam's Avatar
great times but i think it still has alot more in it. the 1/8 mph is good but the 1/4 mph is low i think it should trap like 138+mph definitly a 9 sec car
Old 04-30-2009, 10:22 AM
86 IROC's Avatar
Thumbs up
That is odd, it's only picking up 20 from the 1/8 to the 1/4. Still haulin' *** for a new set up though.
Old 04-30-2009, 11:15 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Congrats, something tells me there's plenty left though
Derek
Old 04-30-2009, 12:30 PM
CARTEK Racing
WS6TransAm01's Avatar
definatly a lot left in it... MPG in the 1/4 is way low...
Old 04-30-2009, 12:53 PM
Restricted User
Still running the same 3.73 gear with the same 5200 RPM converter that I was running on the old nitrous setup that I was spinning to 7200RPM. Due to the stock motor, I'm only spinning it to 6000RPM or so and am hitting the 6500RPM limiter about 100' before the finish. Coasting thru the traps. I think that there will be a couple of videos that will surface in the next day or 2. I will link them.
Old 04-30-2009, 01:19 PM
raymond mckinney's Avatar
Nice set-up! I hope to see you at the next Dead Hookers with the forged motor and some 9 second passes.
Old 04-30-2009, 01:52 PM
theguyulove2hate's Avatar
Those are some damn good runs. Now my questions is what other mods do you have and what do you think it would run with out the turbo?
Old 04-30-2009, 02:08 PM
Restricted User
Maybe 8's
Old 04-30-2009, 02:19 PM
Restricted User
Low to mid 12's maybe. Not sure.As for mods, the longblock is stock down to the valve springs. Only thing in there are hardened pushrods. As for everything else...
Nitrous Outlet Fibertuned Sheet Metal intake
80# Motrons
Stock exhaust manifolds feeding the turbo and true 4" mandrel bent exhaust dumped before the rear axle
TH350 w/ RMVB and 5200 rpm stall (way too much stall for my 6K shift point and 6500 RPM limiter)
S60 Rear w/ 3.73 gear (need to go to a 3.54)
Racetronix plug and play pump setup (way maxed out)
Lingenfelter 2 step
Old 04-30-2009, 08:15 PM
gator's 99TA's Avatar
los, that is a hell of an accomplishment and far from the FL good air in the winter! gotta be fun on a truly budget motor!
Old 04-30-2009, 08:38 PM
00SS4780's Avatar
Congrats again. Can't wait to see the vids!!
Old 04-30-2009, 09:43 PM
86 IROC's Avatar
Thumbs up
Thanks explains a lot. I'll go out on a limb and say you have at least .5 of ET hiding in your set up w/ just a gear change and tightening up the converter. Congrats once again, I have been following your progress.
Old 04-30-2009, 10:05 PM
Josh@PremierAutosports's Avatar
I would tighten the converter way up, you have so much left in it as it sits.
Old 05-01-2009, 06:29 AM
Restricted User
So far only a few pics have trickled out.
Old 05-01-2009, 06:29 PM
860 Performance's Avatar
Wow, great job!
Your making me want to buy one of thoes hair dryers.
Vinny
Old 05-01-2009, 08:49 PM
RacerXLs1's Avatar
Damn, cant wait to see some videos!!!
Old 05-02-2009, 12:41 AM
Restricted User
I think something is uploading now.
Old 05-02-2009, 09:50 PM
Restricted User
Video added to post #1
Old 05-03-2009, 08:39 AM
00SS4780's Avatar
Sweet!!!!!!!!
Quick Reply: Stock LQ9 longblock+PT88=10.07@128
