my new best 10.22 :-)
Old 05-03-2009, 07:33 PM
phoenix's Avatar
Default my new best 10.22 :-)
05-02-2009 18:01:35 Wind from SE at 5 mph, gusts to 7
Station local - Elev : 23 ft Temperature 86.20°
Barometric Pressure 30.01 Humidity 43.00%
Standard Rel Air Density 95.21% Track Rel Air Density 95.30%
Effective Altitude 1682.10 ft Tail Wind 2.00 mph
TIME-LR T
Right Lane
Class GM
Q/P 0
Dial In 0.00
R/T .457
60' 1.399
330' 4.132
1/8 6.463
MPH 104.810
1000' 8.490
1/4 10.220
MPH 129.93
i think i should be able to hit 10.0's once the air cools down
Old 05-04-2009, 01:04 AM
matt94z's Avatar
Nice run, almost single digits.
Old 05-04-2009, 07:08 AM
Restricted User
98Z28CobraKiller's Avatar
What's the setup? I've never seen the car out at PBIR before. I'm there almost every Wed and Fri.
Old 05-04-2009, 07:14 AM
z28rob18's Avatar
nice run man car leaves nice
Old 05-04-2009, 09:00 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Big time congrats. Your car is flying.
Coach
Old 05-04-2009, 10:27 AM
ndfrsd6's Avatar
great 60 ! congrats on the pass
Old 05-04-2009, 07:12 PM
phoenix's Avatar
thanks everyone!
the setup is
stock bottom end ls1, ls6 hand ported heads, 224/224 .589 .589 112 cam, ls6 intake stock t/b, kooks 1 3/8 LT tr6 plugs, but here is the kicker NX 200 wet shot
this was only my 2nd time going i and started going to the GM challenge's every month. i really only go on saturdays. i have been fellowing your setups for a while now, been wanting to meet up with you to talk about ur past LS2 setup. maybe soon i will head up there on a friday.
thanks my best has been a 1.32 i have to thank madman for that
Old 05-04-2009, 11:45 PM
camscam02's Avatar
great pass, very similar to my ms3 cam only times. air really doesnt effect nitrous like na though so you wont pick up much if any.
I also think you should go to a colder plug with that setup. might not see alot of gain but longevity will help im sure. you need a non projectd tr7 or maybe 8's
good luck
Old 05-05-2009, 12:55 AM
MASS seller approved
smok'nZ's Avatar
it say oops no video when i try to watch it
Old 05-05-2009, 09:02 AM
gator's 99TA's Avatar
very impressive for a stock rotating assembly! what does the car run n/a? TH400?
Old 05-06-2009, 06:35 PM
phoenix's Avatar
good luck
well the car was set up for a 100 shot, and i am still on my motor tune. to be honest i didnt think the motor would make it but i have about 15 pass on a 200 shot mostly 1/8 mile, and its still running so i am scared to chage anything lol
i have gone a best of 11.73 i cant recall the MPH right now, i have a th350. how did you know i was running a A3?
Old 05-06-2009, 07:39 PM
A guess, plus listening to the video where the car shifts, how it comes out and...well a guess lol.
i like the TH400 with a small 224 cam combo. it clearly works.
Old 05-06-2009, 11:12 PM
camscam02's Avatar
WOW!!! now that is scary. haha surprised you havnt grenaded it yet. prolly on some borrowed time. it sure does move the **** out....
Old 05-07-2009, 11:38 PM
drop the timing and the motor will go faster and live much longer.
Old 05-08-2009, 06:08 PM
phoenix's Avatar
i thought pulling timming will slow the car down
Old 05-08-2009, 07:53 PM
if you are not detonating. if you are on an n/a tune up, you are likely high 20s degrees of timing at WOT. that is way too high on a 200 shot. you need to readdress your timing and plugs (likely) if you want to keep the motor alive on a 200 shot.
your car will likely go faster. this has been talked about a bunch of times in the nitrous forum. a 200 shot will create a LOT of cylinder pressure for a motor on a hot plug and high amount of timing advance.
Old 05-08-2009, 08:26 PM
waterbug1999's Avatar
Nice... Gives me hope for when I spray the 200 shot!
Old 05-08-2009, 09:52 PM
JRracing's Avatar
Dam dude, that thing is movin out! Nice run. I could tell it was an A3 from the video also. That's the only way to go for a drag car that hits the street.
Old 05-08-2009, 10:48 PM
phoenix's Avatar
well i am pretty sure i am at 24 degrees, i could be wrong i have to check HP tuners. i am not seeing an knock retard during my runs so i dont think i am knocking. But as of right now looks like i will be retiring the LS1 next month to start a LS2 turbo build. i just hope a built LS2 can hold up as long as my stock LS1 did
anyone want to buy a LS1 long block... it has gone 10.22's
well that is what i was going for, a drag car that i drive around on the street
Old 05-08-2009, 11:24 PM
camscam02's Avatar
what is the rear set up? cut stock springs with isolater removed? setup by madman?
Quick Reply: my new best 10.22 :-)
