Why is my car so SLOW!
Well, finally took it to the track today and got some numbers. First two passes were pretty identical.
60-2.0
1/4-14.0
MPH-98
Mods are in the sig, what could be making my car runs so slow? Temps were in the 60-70's, traction was not an issue it just doesnt make any power. FP is 62 at idle and only drops to about 59-60 during a run. Motor has 79k on it.
Put a stock tune back in it and it went 14.7 at 93, so its not in the tune.
Any ideas would be greatly appreciated!
60-2.0
1/4-14.0
MPH-98
does your temp gauge work? i know after i did my lt install i forgot to plug it back in and it ran like ****, i have same mods but true duals and i run an 8.2-8.4 1/8th on bald street tires. somethings very wrong.
Temp guage is working and have a 160 stat, fans are also programmed to come on sooner.
Have done the throttle body 90* check, and is opening all the way.
Here is the breakdown of the best slip;
RT .710
60' 2.029
330 5.924
1/8 9.079
mph 78.70
1/4 14.050
mph 98.78
Could my convertor be junk and slipping this much?
RT .710
60' 2.029
330 5.924
1/8 9.079
mph 78.70
1/4 14.050
mph 98.78
Corrected = 13.426 @ 103.304 MPH
Could be a bit faster.. But I don't think your times are that bad..
Pacesetter LT's ORY Magnaflow catback - will give more mph that ET.. you probably picked up 1/10th to 2/10ths
pcmforlesstune- obviously it helped.. but i am NOT a fan of them
315 Nitto's- your sixty was still a 2.0.. you shouldnt really need drag radials
LS6 intake- more mph than anything..
Get a converter.
/problem!
I have seen someone turned there fans on for a run and lost alot of time. I don't remember numbers but it was .75 I think. Maybe with your fans set cool they are running and drawing amperage and messing with airflow.
I still think that if a chick in a TA with a lid and a catback (and 140k) can pull of 13.6's I should be at least that fast!
the car is down on power, but moreso on the back half where it can stretch its legs. you're only gaining 20mph. you should be gaining at least 22-24. what rpm is the car shifting? any torque management changes?
and if that chick disappointed you...my wife went 13.4 @ 109 in a stock 99 m6 ws6 with a lid and flowmaster weld in haha. sucked for be me because it took headers and an ls6 intake in my 00 a4 car to trap that. but for some reason that ta picks up 25-27 mph on the backhalf. ******* freak.
Torque mangement is disabled and was shifting right around 6k (just leaving it in drive)
well, with that being said. if at all possible, i'd have a live tune thrown on that car and go from there. let me reiterate...a live, GOOD, tune. i don't believe any mail-order tune is optimal. there isn't much to these cars. if the parts are installed correctly and the car isn't seeing any codes, it almost has to lie in the tune. a good live tuner can tell you what your trans is doing.
