ls1 cam heads stall 12.1???
Old 11-20-2010, 07:12 PM
anheuserbusch08's Avatar
Default ls1 cam heads stall 12.1???
i have a 98 trans am stock bottom end stock intake stock fuel injectors, 3200 stall 3:73 gears 224/230 581 588 114 lsa 317 heads ported and polished by me, heads milled.060 and the best i got it to last night was 12.11 @ 113.45 is it running good or should i upgrade to a bigger cam? i want to hit 11s all motor guys please help thanks!!!!!
Old 11-20-2010, 07:34 PM
anyone?
Old 11-20-2010, 08:27 PM
N2RACINGLS1's's Avatar
Well not sure where you are located or what the DA was but I ran 11.94 ET with a completely stock engine internally with just headers, stall, 3.70 gears at 3,665 lbs.
I hope this helps!
N2
Old 11-20-2010, 08:35 PM
I hope this helps!
N2
im located in houston tx
Old 11-20-2010, 08:46 PM
demarco313's Avatar
That STOCK INTAKE is really killing you and is a SUPER RESTRICTION on a head and cam car! You still have the ls1 intake! Upgrade that to at least a ls6 intake (ported ls6 would be better) and ported throttle body. If you really want the best results and the most HP go with a ported FAST intake and a nick williams throttle body. You will see a drastic difference!!!! Make sure when you swap your intake and TB you get your car retuned for the best results! Goodluck Also do you have an aftermarket CAI or stock?
Old 11-20-2010, 09:58 PM
its a drop-in k&n filter with a slp cover
Old 11-20-2010, 10:32 PM
demarco313's Avatar
o ok. thats cool. Get that crappy ls1 intake and stock TB off pronto and retune and you will see a BIG BIG increase!!
well what should i go with?????? please help me thanks
Old 11-20-2010, 10:46 PM
demarco313's Avatar
Depends on your budget? If your on a budget you can buy a nice ported ls6 intake and ported TB combo that ive seen sold on here for about $350 min to about $400 max.
If your not on a budget I would say a ported FAST 90 or 92 with a Nick Williams throttle body. Another suggestion would be to go with the new FAST 102 intake but there seems to be mixed reviews on it for a stock 346 CI motor. Some ppl say its overkill some ppl like it. You would be good with any of the intakes mentioned though and it will be a a significant increase from that stock ls1 intake/TB. Your leaving alot of HP/TQ on the table with that ls1 intake/TB man.
Old 11-20-2010, 10:55 PM
DAMN NICE TO KNOW how will my ET times vary?
Old 11-21-2010, 12:46 AM
Top Fuel's Avatar
what was your 60'? that mph is good for at least 11.70's
Old 11-21-2010, 01:44 AM
1.78 on mt street radial 2's
Old 11-21-2010, 02:04 AM
TrikeMike's Avatar
Still even with the stock intake something is not right. The car is down on power or something. How much experience do you have with porting? A bad port job can hurt power. My car goes 12.2 @ 110 on stock LS1 intake and stock cam and stock 853s.
Old 11-21-2010, 02:11 AM
not much but i did feel the difference over stock 241 heads. it may just be the heads though i didnt polish them as much as i should have.
Old 11-21-2010, 02:20 AM
demarco313's Avatar
This could be true a bad port job could hurt power although we dont know the DA you ran in vs his. He could be running in really bad DA which will result in a much worse et and trap speed. There are head and cam full bolt ons, ls6 intake, P&P TB, gears and stalled cars that trap only around 114-116 (possibly bad DA) so considering OP has the stock ls1 intake/ TB trapping almost 114 isnt bad at all.
OP what HP/TQ numbers did it make on the dyno?
Old 11-21-2010, 02:27 AM
This could be true although we dont know the DA you ran in vs his. He could be running in really bad DA which will result in a much lower low et and trap speed. There are head and cam full bolt ons, ls6 intake, gears and stalled cars that trap only around 114 (possibly bad DA) so considering OP has the stock ls1 intake/ TB thats not bad at all.
it has never been dynoed. but changing from the previous tuner to the one i have now (flaco) i gained 2-3 mph
Old 11-21-2010, 02:42 AM
Top Fuel's Avatar
work on the 60' for sure. what size MT radials? what brand stall? what other bolt ons do u have? what do you have for suspension?
Old 11-21-2010, 02:45 AM
demarco313's Avatar
Aw man.. Car still has alot left in it. Any head and cam car needs to be dynotuned for maximum results. The more power you add the more that ls1 intake becomes more of a restriction. On just a stock car (98-00) ppl swap over to the ls6 intake a dyno it and see nice gains so you will see really good gains with a heads and cam car rather you decide to get a ls6 or FAST intake. Add a ported intake and ported TB then get it dynotuned and it will definitely be a night and day difference!
Old 11-21-2010, 02:58 AM
sounds like a deal i also have a 370 s10 with ls1 intake i should upgrade it as well.
Old 11-21-2010, 03:01 AM
pi 3400 i sent to get reworked on local, torque thrust 2's 17 inch rears on mickey thompson street radial 2's best time off of them was a 1.78 60 ft
Quick Reply: ls1 cam heads stall 12.1???
