What do yall think about this ?
Old 11-28-2010, 07:04 PM
jaysan's Avatar
Default What do yall think about this ?
First time at the track ran 14.3 @ 100.4
car is 02 ls1 m6 , free ram air , lid cat back , 315/35/17 sumitomo htz
Edit : Had half a tank of gas
Old 11-28-2010, 08:02 PM
MASS seller approved
smok'nZ's Avatar
60 ft? put a 315 nitto on there and maybe a chris1313 ram air and cut out
you should be running 12.9 with a 02 ls1 and a lid (in good air)
Old 11-28-2010, 08:21 PM
jaysan's Avatar
my 60 ft was 2.36
Yea I plan on getting nittos . The air temp was probably 70 degrees
Old 11-29-2010, 03:04 PM
jaysan's Avatar
Do these numbers seem right ?
Old 11-29-2010, 03:27 PM
Latch's Avatar
Get that 60' down and you could easily drop a full second off that time.
Old 11-29-2010, 07:54 PM
Lou99Ws9's Avatar
Yea its all in the 60ft! If you can leave the line good enough to get a 2.0-1.9 60ft thats a low 13 all day.
Old 11-30-2010, 12:22 PM
nmass399's Avatar
You don't need nitto's to pull a 2.0 60 ft. Learn how to slip the clutch and easy into it. It took me a while but i finally figured it out. Don't just floor it at the start. I think i remember i would eas out of the whole not real hard then i would finally bog some when i let all the way out on the clutch and thats when i was pretty much full throttle. Then when shifting, you still shift fast but get into the throttle a little easier. Just takes practice.
Old 12-01-2010, 08:16 PM
smok'nZ's Avatar
when was the last time the plugs and wires were changed? did you just buy the car?
