leaving @ 7k and bogging to 3k
Old 07-02-2011, 10:57 PM
adrynalinjunkie's Avatar
Default leaving @ 7k and bogging to 3k
Well I ran for the first time last night on the new et drag stiff walls and was launching at 7 k and bogging to 3k when I looked at the scan. It was knock retarding and pulling 6 degrees right there when I would bog. I tried clicking my front shocks from 3 up to 5. But it still bogged.
I was running 14 psi in the slicks should I start adding more air pressure? Or slip the clutch a little? I am already leaving at 7 grand.
Old 07-03-2011, 04:58 AM
baezi z06's Avatar
Add psi to the tires.... try 16psi and work your way up
good luck
Baezi
Old 07-03-2011, 10:20 PM
John02SS's Avatar
If it is bogging that hard you need more gear. The retard could be false knock as something may be tapping. **** moves around on a 7K sidestep, been there!
Old 07-06-2011, 07:59 AM
1BDHWK's Avatar
It sounds like you definitely need more gear to not have to slip the clutch. Also, to help prevent bog with too small of a gear, raise the tire pressure until you get a rotation or 2 out of the rear tires during the launch before they grab. That will get your rpm up a little. A dead hook launch will take some serious gear.
And John is correct. Lots of things bang around at a 7000 dump.
Old 07-06-2011, 08:27 PM
s346k's Avatar
he could always up his limiter.
who thinks it will bog at 7500? i don't..
nah, really i'd add some air to the tires first. and yes, definitely try to launch at a lower rpm.
Old 07-16-2011, 07:48 PM
hivoltagedriver's Avatar
That motor is good to 7500 too!
Old 07-22-2011, 11:03 PM
SLP IROC-Z's Avatar
what rear gear? sounds like you need to go a higher ratio.
