H/C/I car only trapping 110mph, why??
I just took my Firebird to the track for the 1st time since installing a big batch of mods that include;
Prc stg 2.5 5.3L heads w/ 59cc chambers (11:1)
eps 226/234 cam
comp 7.4" pushrods
Fast 92/92
slp lid
Ford #30 injectors (36@ 58psi)
pacesetter lt's w/ ory and magnaflow 3" catback
homebuilt 4L60E
4000 stall converter
3.23 rear gear
26" 275/55/15 mt drag radial
15" weld prostars
SD tune
My best run of the night (92 degrees in Dayton, Ohio)
12.07@110.81mph
7.64@90mph 1/8th
1.65 60'
My brother was running a firebird with an lq4 and zo6 cam. While he only had a best of 12.88@108mph, he picked up 4 more mph on me in the 8th mile. He's giving up around 100rwhp to me as well. Does anyone have an idea where my mph is? I believe that I should be trapping 115+mph. Help!
eps 226/234 cam
comp 7.4" pushrods
Fast 92/92
slp lid
homebuilt 4L60E
3.23 rear gear
15" weld prostars
SD tune
12.07@110.81mph
7.64@90mph 1/8th
1.65 60'
Internet Mechanic
There are going to be many factors that influence this but with auto cars I would not worry so much about the MPH as much as the ET.
110 does seem odd but again I would ask.
What track, and on what day. To figure out the air quality.
http://www.dragtimes.com/da-density-...calculator.php input and go.
What was the Race weight with Driver, could be just heavy cars.
Has any of these cars been dyno tuned and verified how much power they are making.
IF all is ok, then could be transmission related, be it mechanical or tune related.
Just throwing some things I see in front of me.
Your not far off from me.
Patriot Stage II 227cc Heads 59cc Chambers
224/230 Comp Cam .581/.592
LS6 Intake
Ported Throttle Body
SVO 30lb Injectors
Built 4L65e
3600 Stall
3.42 Gears
I've ran a best of 11.76 @ 114.8, but my average is high 11s @ 112-113ish. What does your 60ft look like? My setup would perform much better with steaper gears but the car is primarily my daily driver. I suspect your gears are holding your mph back. Do you know what rpms your at when crossing the traps? Also. Has the car been dyno tuned? What's the whp?
The DA probably was shitty and that effected the cars performance as well.
LS6 Intake
SVO 30lb Injectors
Built 4L65e
3600 Stall
3.42 Gears
I plugged in the track conditions into the calculator linked above and the da was 3570. Im thinking that ill like my slip as well. The car made 410rwhp and weighs close to stock weight, if not more with the 6 point installed. I usually got in the 1.6x 60ft range.
Yeah just like I thought that DA is shitty. Go on a night when its around 2000 and you'll do much better. Your 60ft is on par tho.
But again, do you know what rpms your at when you pass the traps? Your gears are probably effecting your mph like mine are.
I wanna say its shifting at 6400 rpm, but im not 100% sure, have to check the shift points, and I have no clue what rpm im at while going through the traps.
I've thought about getting the ram air kit, but all my free money is going into my house and school at this time. Maybe ill look into changing that lol.
Sorry for the hijack. Just had a quick question about the ram air kit. What do you think i could pick up on my auto LT1 if i switched to an LS1 lid with the RAM air kit?
The DA was between 3250-3600 that night, my best run came around the 3250 range.
OP do u have it commanded to shift @ 6400? mine is and w/4000 converter its running out to 6850, we found a balance since theres a run out, so its now how we like it..also that DA is killing u!...wouldnt worry so much until its fall..the 3.23"s and looks to be, taller tire combo might hurt a little as well..good luck, keep us posted
