40x results?
Old 03-02-2012, 08:35 AM
MASS seller approved
smok'nZ's Avatar
Smile 40x results?
lets see some 402-408 strokers results
i know there is a 40x dyno results but dynos are gay too many T56 408's
1.84 60ft
7.506 1/8
11.555@121
was on 17" mt's
car has stock gears (3.23) and didnt like the 28" slicks also had to launch in 2 gear for it to hook on the 17's th400
MORE TO COME
Old 03-02-2012, 09:13 AM
badblazeSS's Avatar
ill let you know tomorrow hopefully
Old 03-03-2012, 09:48 PM
badblazeSS's Avatar
7.30 @ 95 in the 1/8
3875 race weight
Old 03-07-2012, 02:25 AM
BayAreaSS's Avatar
1.84 60ft
7.506 1/8
11.555@121
was on 17" mt's
MORE TO COME
You beat a modded zr1 with track times like this? lol
I told you a h/c ls1 could beat you
Old 03-07-2012, 10:09 AM
smok'nZ's Avatar
i was on 28" mt's when i raced the zr1 track i was o0n 28/10.5's which grew too much and were rubbing the fender wells and i was launching in 2nd gear with my 17's it will go 11.0's as it sits with the mt's
what does your car run? or are you too busy posting 3-4000 times?
Old 03-07-2012, 12:24 PM
BayAreaSS's Avatar
lol good one but i'm sure i've been down the track enough. My h/c ls1 making less then 430hp has ran high 10s at mid 120s mph with drag radials on my stock wheels and my car is a 6 speed.
Old 03-07-2012, 09:29 PM
smok'nZ's Avatar
what did it run first day at the track with that set up?
i heard 12's no where near 10's lets see some proof
Old 03-07-2012, 11:19 PM
BayAreaSS's Avatar
11.8 at 120+ on a pretty hot day. First time racing in 2 years and on bald tires
You heard wrong lol
Old 03-16-2012, 11:51 AM
crossbreed383's Avatar
408 ci
super vic
TFS heads
9.90s at 135 in Denver so far only 12 passes w 15% converter slippage
at 8000ft density altitude
would be 9teens or so at sea level
Old 03-17-2012, 12:12 AM
gator's 99TA's Avatar
10.9 @ 125 1.60 on na tune. 460 rwhp
9.74 @ 138 1.33 on about 650 rwhp.
404, ls6 heads ls6 intake stock tb, slp dual dual cat back. 28" et drags. I need to test on radials. 3.73 gear. At least 3600+ lbs. honestly just a bunch of junk thrown together.
Old 03-18-2012, 07:27 AM
subhumanzz's Avatar
9.87@136
6.26@112
average 1.33- 60'
Old 04-04-2012, 09:39 PM
navyblueSS's Avatar
10.82 @ 126 on motor 1.45 60ft.
10.04 @ 138 on 150 shot 1.68 60ft. on 275/50/15 MT DRs
About to order new Hossier 275/60 DRs, running out of gear with the 26s.
LS2 402 with Trickflow 215 heads, 3.42 gears, and 3600lbs.
Old 04-05-2012, 09:52 AM
odarabla's Avatar
LS2 402ci, reworked trick flow 215cnc heads
EPS custom cam, Th350, PTC stall, Strange
12bolt, Billet wheels on 28" tall Dr's and skinnies
in the front, Race weight is 3540lbs
1.41 60ft
6.6@101mph 1/8th
10.39@129mph 1/4
Next comes the spray..
Quick Reply: 40x results?
