LG G6x3, AFR, stock bottom end...M6
Fist time out with new car
Was very happy
It has more in it ... We fought a 20 mph headwind
M6 car
afco shocks and springs
M9 rear and tq arm
LG g6x3 ,AFR 225 ,fast 102,4.56 gear
470rwhp
1.38 60ft.
6.6 1/8
101mph 1/8
10.48@129mph
Damn track camera man took a bunch of pics
But missed the 4foot wheelie I had
Thanks mike Norris for the great build and tune
Thanks LoUis gigloitti for all your fast parts
Was very happy
M6 car
M9 rear and tq arm
470rwhp
1.38 60ft.
6.6 1/8
101mph 1/8
10.48@129mph
i had a feeling that's what you're using...that's my next clutch...RXT?
do you happen to know your raceweight?
what spring rates on those afcos (front/rear)? do you happen to have a picture of the stance of the car? I'll eventually switch from the strano setup to an afco setup in the future.
have a similar setup as far as power...would love to crack 10's with an m6...thanks for the feedback
Fronts are 275lb springs
Stock rear springs
Setting 6 fronts
7 on rear
15psi in tires
28et drag S
Stange drag breaks
Bmr k member & control arms
Burkhart lca Drag bar pan hard bar
Don't know shift points
No aftermarket tach or shift light
Lol haven't even seen dyno sheet to see where it stops makeing power
Stock rear springs
Setting 6 fronts
7 on rear
15psi in tires
28et drag S
Stange drag breaks
Thanks Rob
I will say the suspension is great
The car does not nose dive between shifts
Doesn't bounce after the wheelie or bounce up and down going down the track
