11s posible ? Torquer v2
Think 11s are possible na ?
99 z28 a4
Torquer v2
Stock 243
Ls6 intake
Long tubes ory
P&P trottle body
25% underdrive pulley
Lid
Yank ss400
42lb inj
Stock 4l60e
Stock rear
-Air
-egr
Mickey Thompson et street radials 275/60/15
Slicks and skinnys
Think it's got 11s ?
Old 01 z28 ran 12.5 with lower stall lid and long tubes untuned with similar size slicks .
So I hope so .
What will it run on a dry 100 shot the car will be tuned for ?
Care more about my na times
Any input ? Similiar set ups ?
Thanks ! Will post tune numbers then track numbers asap
99 z28 a4
Torquer v2
Stock 243
Ls6 intake
Long tubes ory
P&P trottle body
Lid
Yank ss400
42lb inj
Stock 4l60e
Stock rear
-Air
-egr
Slicks and skinnys
So I hope so .
Suspension is stock . With out the pro starts its very low key not lowerd .
Might put in some v6 rear springs . But that's as far as suspension goes .
What are typical torquer v2 times ?
a lot of things about our setups are similar, my heads are slightly worked but not much and you have less weight and more stall
My best is 11.6 and best mph of 117 so far. This is before I put the HD 2-3 shift valve in the transmission so it always hit the limiter a little and shifted lazy. Now it nearly chirps tires on the street shifting to 3rd. For comparison it is running 7.4@95mph in the 1/8th on a 1.7 60ft
with the stock 2.73 or 3.23 gears that you have and a 60 sidewall tire the car is gonna be a dog! your gonna need to go to a steeper gear or a shorter tire or else id bet you will not be happy with your times.
The proper setup tqv2/ss4000 should easily go 11.40's in good air
Well those seem to be great times . 11.80s would be awesome and a 11.3 would be great on the bottle .
The car has 3.23 gears and aluminum drive shaft .
This is a quick project and only wanted it to run 11s built it in 3 weeks to race a co worker an will probably sell in after the race . Lol
Just need to make sure it runs good and clicks off mid high 11s before its sold !
Anyone else ? I knw a lot of people run the torquer v2
Just for reference. My car which has the TSP Torquer 2 on motor with 6sp at almost full weight went 11.7 at 118. With my nitrous converter after the th400 swap 11.8 at 115. Now with the same cam like 5 years later with heads and intake just went 9.31 at 146 on .99 jet. This is a proven cam.....
Theres a lot of tall tire with littler gear cars on here that are stuck in the 1.7 60's and are about 3 mph low at the topend than what they should be at. Little tweaks and theyd see a big difference
As for the 28" tall tire I got both tires for $200 almost brand new . I knw they are not ideal for the a4 and rear gear but I should dead hook .
As far as what my expectations were 11.80s were the goal on motor and by the looks of things that might have been conservative . Spray didn't really matter was hoping the 100shot put me .4-.5 faster but wasent too worried and it will only be used when needed ( race against a faster car )
Kit is almost completely hidden
Has anyone ever gone slow with the torquerv2 and a a4 ?? Lol
Coworker runs 12.40s and wanted to make sure during the race I could put a few car lengths on him .
Well got the car running and transmission took a **** .
I do have a rossler terminator th400 sitting on the floor from another project I nights just trow in. , its a manual reverse valve body with transbrake and a Hugh's 4500 rpm converter .
Will it go faster or slower than the 4l60 an yank 4000 ?
Now I plan to up the shot maybe to a 125 and spray out the hole .
I guess rear end is the next thing to go ! Lol
No need for a 28" tall tire unless youve got a lot of gear and have rpm restrictions, or you simply cannot hook IMO.. little tires are lighter anyway if you believe in that
Shorter tire and gear should help some, but not enough between being a "dog" or not IMO.
Decided against the th400 and had a local trans shop do a rebuild for a great price transgo shift kit and reybestos heavy duty clutches 1yr warranty 12000 on parts and labor
2day turn around time
