opinions on times ... turbo t/a
99 ls1 228r on3 76 mm 7.5psi
Dyno says 528rwhp
I only got to run 4 times so think I can go faster
Reaction .4185
60 ft 1.7498
1/8 7.6120 at 97
1/4 11.6 at 119
da was 1146
I did trap 123 one run but my 60 stunk so I ran a12.3
My launches were bad I'd either spin or bog because I don't want to break the 10 bolt ... I was on mt/et streets 26x11.5x17 at 15psi and comp 3 way shocks . Non adjustable lca and panhard.... thanks for any input before hand
Dyno says 528rwhp
Reaction .4185
60 ft 1.7498
1/8 7.6120 at 97
1/4 11.6 at 119
da was 1146
Dyno says 528rwhp
Reaction .4185
60 ft 1.7498
1/8 7.6120 at 97
1/4 11.6 at 119
da was 1146
Dyno says 528rwhp
Reaction .4185
60 ft 1.7498
1/8 7.6120 at 97
1/4 11.6 at 119
da was 1146
He could be making that power but no two-step and boost drop for shifts... I still say that should be closer to 126-130 mph trap depending on weight .
You sure your clutch is holding tight? Also, what gears and what rpm going through the traps? You're only picking up 23mph from 1/8th to quarter... That's more like a H/C gain IIRC.
