First time out with new car and set up
Went to the 1/4 mile track this Friday I was hoping for a better time and mph n/a but it was hot as hell out so that mite be part of it
Setup consist of
98 Ss ttop a4 front sway bar and a/c delete are the only weight reduction not sure what it weighs with me I guess 3500
It's a aluminum 6.0 with forged pistons and rods stock crank
Patriot 5.3 heads cr 11.2:1
Lsr 231/239 cam
Ls6 intake
Open tsp y pipe for exhaust
Stock 10bolt 3.73s
Performabuilt 4l60
Fti3800 stall shifts at about 6200
Racetronix kit
Nos plate with 150 shot 65n 38f jets
3 point subframe connectors
Bmr torque arm
Viking da shocks front and back 300lbs springs
Pro stars with 275/50/15 Mickey Thompson drag radials at 14psi
First pass spun bad n/a
Rt .031
60ft 2.2
1/8 8.8 90mph
1/4 13.1@116
Second pass n/a
Rt .118
60ft 1.63
1/8 7.32@93.4
1/4 11.51@117.26
Third and last pass turned on the juice bottle pressure about 950
Rt .424
60ft 1.44
1/8 6.52@105
1/4 10.26@131
Temps that night were in the 91-92 degrees
The track was packed so I only got two good runs in I thought I was gonna trap at least 120 n/a but guess I need to dyno tune it maybe bring up the shifts to 6500-6700 what do you guys think?
Setup consist of
Lsr 231/239 cam
Ls6 intake
Stock 10bolt 3.73s
Performabuilt 4l60
Racetronix kit
Bmr torque arm
Rt .031
60ft 2.2
1/8 8.8 90mph
1/4 13.1@116
Second pass n/a
Rt .118
60ft 1.63
1/8 7.32@93.4
1/4 11.51@117.26
Rt .424
60ft 1.44
1/8 6.52@105
1/4 10.26@131
But my last car hardtop formula was a stock bottom ls1 with the same heads and 228r cam and ran 7.1@95mph but it also only weight 3300 with me in it thinking I mite need to pull out the leather seats and start some weight reduction
Well guys I went to the track last nite and made one motor pass picked .3 tenths and 4mph and bettered the 60ft by .1 this was after adding a umi drag bar umi k member and sux2bu ram air we also had better weather
Turned the kit on with a 200 and disintegrated the 10 bolt I went 1.4 60ft 10.00 @135 last time out guess it wasn't having it tonight
Nice run.. Do you think the SUX2BU is worth the it? I've been thinking about doing something similar..
