Post up fastest 17,18,19,20" inch wheel drag radial passes.
Old 09-27-2015, 03:35 PM
nmass399's Avatar
Default Post up fastest 17,18,19,20" inch wheel drag radial passes.
Been trying to figure out how fast people have been on a really really small tire.
Was considering coming up with a class my local track could run. Would be nice to have a good street car class with everbody on a really small tire to limit et's. Having 1 minimum weight and letting everyone run what they brung on power combo's. Basically letting the tire be the equalizer.
I was looking at running a wide variety of different sizes but limiting sidewall height to help slow everyone down. Or just running one size period, like the 275/40r17.
No doubt someone can probably come out there and run a crazy fast number on that tire but thats why im asking how fast everyone has been.
Other rules ive been thinking of would be a 20 to 30 mile cruise,
17x7 or larger wheels up front,
no drag brakes,
between a 3200 to 3500 minimum weight,
two front seats-can be drag seats and rear seats can be removed,
full interior as in carpet, dash, door panels,ect.
must have working alternator-power steering can be removed and so can a/c
no c02 with boost controller Maybe no boost controller at all, and maybe no progressive nitrous controllers.
forgot to mention i think 1/8th mile would be best so high powered cars could not pass u on the big end
Also post up info if another track has or is doing this now.
Post up guys, need your help with info.
Thanks
Old 09-27-2015, 08:41 PM
BODUKE's Avatar
no drag brakes,
Thanks
I run a 16 inch drag radial that was factory size dont leave us out.
Old 09-27-2015, 08:47 PM
Tuskyz28's Avatar
It's a old thread but it's a 2000 Z28 on here with a 402 ci 6 speed with afr heads that went 10.7 I believe on a 275 tire on a a 17 inch vette wheels...
tires was Hoosier QTP
Old 09-27-2015, 09:03 PM
nmass399's Avatar
16's have alot of sidewall, i want to keep all the bigger tires out of the class. The idea is to keep the class in the 6's and slower in the 1/8th mile. The smaller the tire the harder it will be to put any power down.
Old 09-27-2015, 09:06 PM
nmass399's Avatar
Nice, not a bad et for a 6 speed car.
Old 09-28-2015, 12:21 AM
Tuskyz28's Avatar
The big deal with small tire cars is all suspension. Spend money on great shocks. Always run a double adjustable rear shock is one of the main keys. A short torque is nice too like one from Midwest chassis.
Old 09-28-2015, 09:11 AM
SCott5's Avatar
A 275 is not a small tire anymore.. Small tire is x235 class
Old 09-28-2015, 11:28 AM
nmass399's Avatar
Exactly comes down to suspension and such to get down the track.
Not talking about on a 15 inch wheel, 17 inch wheel to 20 inch wheel
X235 tire is a lot bigger tire than I would wanna run, I'm talking about a 26 inch tall tire max on a 17 inch wheel. The idea is to keep high powered cars limited on putting power down as far down the track as possible. If I could do it, I would get everyone to run something even smaller height and width wise on a 17 inch or 18 inch wheel than the 275/40r17
Old 09-28-2015, 03:12 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I been 11.3@124, 17x7 up front, and 305/45r18 DR's in back on 18x10.5 rims. I'm over 3800 raceweight in this 2010 5th gen.
Old 09-28-2015, 06:46 PM
nmass399's Avatar
What's ur best 60ft and 1/8th mile on those tires John
Old 10-07-2015, 06:04 AM
LEO
LEO's Avatar
I've run a 11.55 @ 120 on Nitto 555R 305/35/ 20" drag radials.
Old 10-07-2015, 12:37 PM
nmass399's Avatar
After seeing mighty mouse run low 9's on a 17 inch 315 and a turbo coyote run low 9's on 20 inch drag radials, I'm a little discouraged. Maybe a class on 200 tread wear and higher with short sidewalls plus being on a 17 inch or larger wheel. Not sure how the people running the track would like all them street tires eating it up. No awd vehicles also.
Old 10-12-2015, 09:49 AM
MIGHTYMOUSE's Avatar
great thread. lemme bump it
1.35 on 315/35-17 MT2
1.33 on 295/45-17 MT2
the new R should work better.
http://www.summitracing.com/parts/mtt-3571/overview/
Old 10-13-2015, 05:26 PM
nmass399's Avatar
Yeah that's the vid I watched, I had forgotten you ran on 17's for a while. I've always wondered what the fastest pass is on a 17 inch and taller rim. Have not found a list yet or a class that has to run them
Old 10-14-2015, 04:10 AM
Nicelysedate's Avatar
Not a drag radial but I've gone 11.89 @ 115 on 17" Continental DW's with a 1.67 60 ft with mods in signature in 1500ft DA air.
Old 10-14-2015, 07:32 AM
HioSSilver's Avatar
I went 11.52@122.xx on 18s with a 1.83 60'. No dr but r compounds. I was all over the rev limiter before the traps in 4th.
Old 05-02-2016, 09:14 PM
zukboi2004's Avatar
Old 05-02-2016, 09:19 PM
zukboi2004's Avatar
I hope this guy doesn't show up to your radial night
Old 05-02-2016, 10:01 PM
nmass399's Avatar
After I realized how fast everybody could go on that small of a tire I decided it was a wasted effort. Can't really even out a field on a small tire for the slower cars. Even cars on a very normal street tire can be pretty fast. I would still like to see a class out there running 17 or 18 inch wheels and drag radials for an even smaller tire class than x235. Would be really neat to watch.
Old 05-02-2016, 11:08 PM
BSmiff's Avatar
These guys on 235s are basically proving tires arent the limitation. You have to limit something else.
Quick Reply: Post up fastest 17,18,19,20" inch wheel drag radial passes.
