The LS1TECH '69 Camaro goes 10s!
Old 12-10-2004, 10:49 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Talking The LS1TECH '69 Camaro goes 10s!
Just got home from Houston Raceway Park. I only managed to make two passes, on the third attempt I raised the launch rpm up to around 6000 rpm (from 5500) and broke the driver's side axle shaft. Time for some bigger shafts, these are just stock 12-bolt shafts.
Anyways, here is the important info:
Car: 1969 Camaro SS, 6-speed manual, 348ci LS6, stage 2 heads, 232/232 cam, Magnacharger. 3.73 gears, Hoosier slicks on Pro Stars. Raceweight was 3435 lbs.
Weather conditions: 62F, 29.89 barometer, 39% humidity
First pass
60'=1.62 (13 psi cold tires, 5200 rpm clutch dump)
1/8=6.99
mph=101.42
1/4=10.88
mph=126.10
Came immediately back around and lined up again (no cool down)
60'=1.60 (no change in tire pressure, 5500 rpm clutch dump)
1/8=6.95
mph=101.05
1/4=10.87
mph=125.01
Did yet another lap, lined up, dumped the clutch at 6,000 rpm and POP goes the axle. It also managed to shred the supercharger belt when the axle broke, because the revs jumped up so quickly.
Well, my initial goals of running 10s with the blower are done. I'll be installing a fresh set of larger axles, larger spline count posi, and adding the NX nitrous kit next. Going for 9ssssss!
A friend video taped the 10.87 pass, probably have it up in a few days.
Tony
Old 12-10-2004, 10:57 PM
Wesley SS's Avatar
Congrates on the great times, sucks about the axles. I remember your car at thunder that thing is sharp.
Old 12-10-2004, 11:00 PM
2 SLOW's Avatar
I bet the car looks great going down the track that fast also! I'm tired of the usual all out trailer cars that look like garbage and struggle with low 11's.
Old 12-10-2004, 11:08 PM
CamaroCain's Avatar
Congrats Tony!
Old 12-10-2004, 11:14 PM
BIGBOS's Avatar
Thats awesome, congrats
Old 12-10-2004, 11:15 PM
frcefed98's Avatar
Damn Awesome Tony!
Too bad about the axle.
J
Old 12-10-2004, 11:35 PM
JS
JS's Avatar
Awesome Tony,Now for the 9's
Old 12-11-2004, 12:27 AM
ThunderZ28's Avatar
that was a hard to watch tho Tony
I was in the staging lanes right behind you when it went....
but glad to hear you made your ten second passes
Old 12-11-2004, 12:33 AM
Camaro Zach's Avatar
Congrats
Old 12-11-2004, 12:50 AM
Moderator
BizZzatch350's Avatar
Bad ***, cars running stout.
Old 12-11-2004, 01:43 AM
distortion_69's Avatar
Gotta love a car thats clean enough to eat off but runs 10's.. I just sat staring at that car for 20 minutes at Thunder.. Its what I've always wanted to do, but never been able to afford
Old 12-11-2004, 02:21 AM
TT-TECH Veteran
Inspector12's Avatar
Wish I could have been there to see the passes Tony Congrats!
Jeff
Old 12-11-2004, 02:37 AM
MRI-TEK's Avatar
Way to go !!!
Old 12-11-2004, 07:46 AM
beardWS6's Avatar
Nice job Tony. What are you going to do with the X1 you bought from me? Good Luck!
Old 12-11-2004, 07:51 AM
LS1Tech Co-Founder
Nine Ball's Avatar
X1 goes into Lisa's '00 Trans Am. Yes, there are 4 LS1 f-bodies at my house
Old 12-11-2004, 10:02 AM
Scooter70's Avatar
Congrats Tony. Is PSJ scared that he's going to lose the bet now?
Old 12-11-2004, 10:30 AM
beardWS6's Avatar
I bet the driveway looks sweet!
Old 12-11-2004, 11:43 AM
NA$TY-TA's Avatar
AWsome Tony.......... its time for NAWSSSSSS ha ha So around new years you should be back up and running to get that 9 sec pass in 04???
Kyle
Old 12-11-2004, 11:48 AM
Brandon Boomhauer's Avatar
Damn that still movin. When are you going to get everything finished up?
BTW when did you get the 1LE? I've seen the pic a time or do, but no thread....
Old 12-11-2004, 12:26 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,102 Likes on 723 Posts
Congrats on the new ET!
Not skeered here about which one of us runs 9's first, first good weather I get I am hitting a track.
Quick Reply: The LS1TECH '69 Camaro goes 10s!
