More AFR and MS3 times
I only had street tires (Kumho Ecsta's 285/40/17's)
I raised the shift point and want to check it out, the first tune would not shift out of any gear
2.292 8.745 88.79 13.278 104.69
2.334 8.858 89.10 13.346 108.73
2.042 8.795 86.20 13.385 106.56
changed the tune and went back
2.046 8.003 92.02 12.318 113.96
2.102 8.092 92.22 12.408 113.93
with a 100 shot
2.033 8.030 95.54 12.108 121.57
2.018 7.933 96.33 11.988 121.92
with a 100 shot
Restricted User
Andrew, are you still having issues with the P0106 code? If so, wait til you get the MAP Sensor issue fixed before making any more comparitive runs. Looking like your well into the 11s on motor if you get the 60' under control. You are still spinning well after the 60' also. A 21mph gain in the top half is good, but should be a little more once the combo is sorted out and tune dialed in. Hopefully you getrdone before I get back
Charlie
Charlie
