track results with new combo
Old 07-22-2006, 12:28 PM
Juicedz's Avatar
Default track results with new combo
I've hot a 11.1 355" with afr's 24x/24x cam .5xx/.6xx It has a vigilante 4000 stall n/a it put down 385 through thr th400. I'm sraying an nx dp kit 200 shot. It put down 550hp. My race weight is about 3550 with me in it. We only have a 1/8 mile track here. I ran 6.92 @ 101. Which should be about a 10.75 in the 1/4. The weather was about 70 degrees and I was cutting 1.52-1.54 60'. Is there something way off in my mph If I put 550 down through a t400 and 4000 stall? Another thing, I/m running 114 leaded with no knock retard but only picking up about 160 on a 200 shot? Do I possibly need to run a colder plug? I'm running tr-6 gapped at .035. Thanks in advance guys
Old 07-22-2006, 02:54 PM
slimcracka's Avatar
i dono if the gap is right sounds a lil small but your trap is def. off a lil..what gear are you runnin and what size tires? you should be about 104~105...
Old 07-22-2006, 03:31 PM
Juicedz's Avatar
I'm running m/t 28 x 10.5, with 4.10 gears. Why do you think the gap is off? Is it because the gas I'm running?
Old 07-22-2006, 05:06 PM
slimcracka's Avatar
ive never herd of a gap that small...but your car is a lt1 so i dono but my gap is at .55
Old 07-22-2006, 08:49 PM
Juicedz's Avatar
anyone else have some input?
Old 07-23-2006, 09:39 AM
GS WS6's Avatar
You prolly dont need all that octane, you should be fine on 104......your prolly losing some power because the car is working hard to burn all that fuel due to the 114
Old 07-23-2006, 10:28 AM
Juicedz's Avatar
I think the highest unleaded around here is 100. How much timing should I pull with a 250 shot and ngk-tr6?
Old 07-23-2006, 10:38 AM
NOTFAST's Avatar
gap seems about right to me
Old 07-23-2006, 06:50 PM
NX_CaGEdApE00's Avatar
mix some torko with 91 or 93 octane in doing this we have gotton 108 octane...
u should pull 7 degrees timing for a 250 shot... but with that gas u could get away with pulling 4 - 5 degrees....
how u likeing the MT tires FALCONE..... they rule..
Old 07-25-2006, 11:53 AM
Juicedz's Avatar
I like the m/t , 1.52 60' so far.
Quick Reply: track results with new combo
