All Time Fastest NA LS any C.I.
Old 07-15-2007, 12:43 AM
AshWS6's Avatar
Smile All Time Fastest NA LS any C.I.
Top 25 6/20/9
8.69 @ 156 403in Joe/Amber 3195# Solid Cathedral
8.74 @ 155 Matt # Solid C5R
8.75 @ 153 427in Judson/SAM 3200# Solid C5R
8.95 Camnhawk 3100# Solid C5R
9.16 @ 147 770Guy 3240# Solid C5R
9.23@148.27 418in Revlimiter 3250# Solid ET canted valve
9.241 @ 146.29 430 Coleman Roddy 3180# Hyd Cathedral
9.39 @ 146 427in TNTAddict 3200# Solid
9.39 @ 141 445in TXCAMSS 3110# Hyd Cathedral
9.46 @ 141.98 440in Firehawk441 3200# Solid LS7
9.47 @ 140 427in RUQWIKR 3130# Hyd Cathedral
9.504 @ 141.06 427in LTZSS 3408# Solid Square
9.505 @ 143.31 427in AshWS6 3220# Hyd Square
9.56 @ 139.9 TomTheRoofer Solid
9.59 @ 138 441ci Tektrans 3240# Hyd L92's
9.60 @ 414in GTS SS Solid
9.65 @ 139 Mikey Solid
9.66 @ 140 TSP 431in 3175# Solid LS7
9.68 @ 139.8 408in Fear the LS1 3365# Solid Link
9.69 BeaSSt 3050# Solid
9.703@144.83 DBN 427ci 3200# Hyd ETP LS7 heads.
9.71 @ 141 421in Tosto 3450# Solid
9.74 @ 141 427 NOYZEE 3300# Solid Cathedral
9.74 @ 138 454 1cdub 3200# Hyd Rectangle
9.82 @ 137 402in OneBadWs6 3150# Hyd Cathedral
weight, cubes, compression, valvetrain, cathedral or squareport (c5r, LS7)
ETDatabase doesnt seem to jive
AshWS6 is offline
Old 07-15-2007, 08:31 AM
gator's 99TA's Avatar
https://ls1tech.com/forums/drag-racing-results/741608-new-lsx-na-record-8-8749-153-02-a.html
https://ls1tech.com/forums/drag-racing-results/745027-9800-rpms-pure-fun-sneak-peak.html
all three cars are cathedral port headed lsx motors. one is the cr5, other is an ls2.
gator's 99TA is offline
Old 07-15-2007, 09:40 AM
AshWS6's Avatar
8.87 @ 153 Matt # Solid
9.26 @ 148.5 414in Joe/Amber # Solid
9.42 143.3 402in Revlimiter 3250# Solid
9.61 TomTheRoofer Solid
9.65 Mikey Solid
9.69 BeaSSt
9.8 @ 138 402in TNTAddict 3260#
9.96 @ 133.5 408in James/Sheila Day 3440# Hyd Cathedral
Updated!
AshWS6 is offline
Old 07-15-2007, 10:42 AM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Our race weight is right at 3440#-3450# depending on fuel. We are not quite in the same league as these guys. We plan to be some day, but we are staying on the street and in pump gas mode
Once we commit to giving up the stereo, heater, defroster etc we'll shoot a little higher. Expect some 9.6-9.7s this Fall once we step into an aluminum block and let Greg Good build us another set of heads
Those top 2 still amaze me.
TXCAMSS is offline
Old 07-15-2007, 04:34 PM
matt346ls1's Avatar
Good luck, once you drop some lbs it will be a little easier.
matt346ls1 is offline
Old 07-15-2007, 05:58 PM
TOSTO RACING's Avatar
I always wonder what my could have ran at 3000 or 3100 lbs.
My motor was a 421 ci
TOSTO RACING is offline
Old 07-15-2007, 07:01 PM
TXCAMSS's Avatar
Back to the other specs request. I got busy and had to run but here ya go:
Cubes - 408 Iron block
Compression - 11.8:1
Heads - Cathedral port stock based 5.3 heads that were heavily massaged by G Good.
Valvetrain - Morel Hyd lifters, stock HS modified rockers, PP springs
Weight - 2 dang heavy
Fuel - HEB grocery store 93 octane
Shift points - 6500/6600
Tune - Stock PCM with HPTuners OLSD
Gears - 3.90:1
Tires - 29.5" Hoosier Drag slicks and 27" front runners
Tranny / Converter - Circle D 4L60E and 9.5" converter
Exhaust - 1 7/8 Kooks w/3" y-pipe with dual 3" cut-outs and SLP dual/dual catback
Don't know why it works.....but it does (Actually I do know why and I'd tell ya, but I'd have to kill ya )
A special thanks to Greg Good , Erik Koenig (HKE) and Circle D Specialties (OOoops )
TXCAMSS is offline
Old 07-17-2007, 10:34 AM
Bryan @ Speed Inc.'s Avatar
where's camnhawk at 8.95???
Bryan @ Speed Inc. is offline
Old 07-17-2007, 12:01 PM
revlimiter's Avatar
I fit in there somewhere @ 3250#'s
revlimiter is offline
Old 07-17-2007, 12:16 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
8.87 @ 153 Matt346 # Solid
8.95 @ 151 CAMN HAWK, 4__ci, Solid, 3100?
9.26 @ 148.5 Six Speeds (Joe/Amber), 414ci, Solid
9.42 @ 143.3 NA revlimiter, ___ci, Solid, 3250
9.6x TomTheRoofer
9.71 @ 141 42xin Tosto 3450# Solid
9.9x @ 13x 408in James/Sheila Day 3440# Hyd
Pro Stock John is offline
Old 07-17-2007, 12:20 PM
ATVracr's Avatar
9.9x is the fastest HYD. car?
or was Tom the roofers car HYD.?
ATVracr is offline
Old 07-17-2007, 01:25 PM
Tom the roofer's Avatar
Mines solid. 9.61 about 8 times in a row lol. SAM car went 9.50 or possibly faster. Mikey at 9.65 and BeaSSt at 9.69. I can't remember anymore N/A LS cars.
Tom the roofer is offline
Old 07-17-2007, 03:31 PM
TNTaddict's Avatar
dose an LS2 402ci Hyd,,,3260 lbs,,count??
if yes then i'm in,,,,
TNTaddict is offline
Old 07-17-2007, 03:44 PM
LS1Tech Co-Founder
Sure does count, great job.
Judson went 9.12 or 9.17, I forget. This was in 2005 or 2004.
Old 07-17-2007, 03:48 PM
The Juggernaut's Avatar
OneBadWs6 N/A LS2 402 HYD went 9.82@137 3150#(I think)
The Juggernaut is offline
Old 07-17-2007, 03:53 PM
TNTaddict's Avatar
thank you,,
is there a Top 10 or 20 yet?? we need a list for that..
and by the way,,it's an 402 LS2,AFR 225(comp, 11.4), Fast 90/90, hyd, TH400 and 12 bolts,,,3260 lbs,,
Old 07-17-2007, 04:01 PM
AshWS6's Avatar
can you guys post up your 60/330/660 also I want to check something out, I think this thing is soft in the middle
AshWS6 is offline
Old 07-17-2007, 04:17 PM
SAM car went 9.17 i believe.
Old 07-18-2007, 05:36 PM
Gary Z's Avatar
Most, if not all, of these cars have manual transmissions.
Gary Z is offline
Old 07-18-2007, 05:50 PM
TXCAMSS's Avatar
Built 4L60E here
TXCAMSS is offline
Quick Reply: All Time Fastest NA LS any C.I.
