H/C Vig 3600 3.73 goes 12.4 at 108 HELP!
Old 07-03-2008, 07:50 AM
99ccz28's Avatar
Default H/C Vig 3600 3.73 goes 12.4 at 108 HELP!
I have a full bolt on car. Headers, exhaust, ls6 intake, pulley. 224 cam and tsp prc 2.5 5.3 heads, along with the Vig 3600 and 3.73's. I also have lca's, relocation brackets, panhard bar, and bilstein shocks/struts.
Last year I had a slipping tranny, I went 12.2 at 112. I thought that was bad!
This year, I installed a built transmission, a nitrous plate kit, and a racetronix fuel pump. Went to the track last night and ran a 12.4 at 108. My 60' was 1.7. My car trapped 86 in the 1/8th. All NA.
Here is the slip from my 12.5 run:
60' 1.78 (worse than last year)
330' 5.14
1/8 et 7.97
1/8 mph 86.17
1000' et 10.44
1/4 et 12.51
1/4 mph 108.62
The car is hard to start at times. It will just turn over but not start. Like it is not getting fuel. I have a dyno tune, but I think someone may have done something to the computer and possibly did something. Not sure though.
Any help?
Also, for the nitrous I have a timing tuner. So there should full timing on NA runs.
Old 07-03-2008, 11:33 AM
02 BLK WS6's Avatar
You need to get that sucker tuned on the street. I found out the hard way that the dyno didn't put enough of a load on the motor and caused my car to go lean on the bottle resulting in a burned valve.
Old 07-03-2008, 11:38 AM
99ccz28's Avatar
Im not even worried about the nitrous at this point. I just need to find out why my car is running like crap on motor.
Old 07-04-2008, 08:03 PM
Dan
Dan's Avatar
#1 your 60' is crap for what you have..what tires are you running? Are you spinning?
Old 07-05-2008, 09:55 PM
30th t/a's Avatar
60' is the last thing id be worried about. MPH = rwhp and that is what he is lacking, bigtime. He should be 114-116mph but yet is only trapping 108.
Old 07-05-2008, 10:27 PM
Dan
Dan's Avatar
Well 30th bud..he has multiple issues, not just MPH..You don't need a lot of power to pull a good 60'
Old 07-06-2008, 10:44 AM
99ccz28's Avatar
My 60's are still worse than the 60's i was pulling last year.
Old 07-06-2008, 03:50 PM
30th t/a's Avatar
yes but that could have been track prep, air pressure that you were running that night or maybe just how your launching that night. Be more concerned about that 7 mph that your missing over .1 with your 60'
Old 07-06-2008, 04:58 PM
99ccz28's Avatar
I am. I am just saying that everything is worse, not just one or two things.
Old 07-21-2008, 08:30 AM
burritoboy9984's Avatar
you dyno it after you did the latest installs?
-Erik
Old 07-21-2008, 08:45 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Do you have a tune, and have you logged it for knock retard? Too much advance will make it hard to start and could cause your lack of power as ell
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Quick Reply: H/C Vig 3600 3.73 goes 12.4 at 108 HELP!
