Drag Racing Tech
Is this enough motor plate ?
Old 04-12-2009, 11:30 PM
JBM
JBM's Avatar
Default Is this enough motor plate ?
Wondering if this will be enough motor plate, have to remove some for the alt., and drysump pump.
Old 04-12-2009, 11:39 PM
chvypwr31's Avatar
how thick are the plates, and are you using a midplate also
Old 04-12-2009, 11:45 PM
JBM
JBM's Avatar
1/4 inch front plate, yes going to use a .090 steel mid plate
Old 04-13-2009, 12:16 AM
chvypwr31's Avatar
yea that will be enough support then
Old 04-13-2009, 12:31 AM
JBM
JBM's Avatar
even after cutting out for the alt, and drysump pump ?
Old 04-13-2009, 01:03 AM
chvypwr31's Avatar
from the pictures it looks like theres a good amount of meat left outside of your cut line
Old 04-13-2009, 06:14 AM
Fireball's Avatar
About the same as what I have
Old 04-13-2009, 06:51 AM
Race your car!
JL ws-6's Avatar
Mine's held on by the water pump bolts only and has been that way for a year, no problems at all, and I'm running just the motor plate. I do have a torsional support bar attached to the frame by one of the holes that normally attaches the a/c pump
My plate is 1/4 inch thick too fwiw.
Old 04-13-2009, 12:16 PM
TT632's Avatar
I had to do similar mods on mine. With a mid plate it was good for over a 1050 hp to the ground
Quick Reply: Is this enough motor plate ?
