summit pro star?
summit pro star?
im thinking about buying 2 for the front of my can. There are 15x4.. what backing spacing,spacers, and lugs nut do i need.. plus how much go yall think they will pick me up in the 1/4. im running a 16x8 camaro wheel with 245/50/16... thanks alot
i had a set on the front of my car and it wasnt a huge noticable difference in et in the 1/8th dont know about the 1/4 considering they are not all that light weight as opposed to the weld wheels i didnt have to run a spacer with the summit wheel. and they use the conical 1.5 x 12mm lug nut, i have a set of 15x3.5 weld draglite skinnys for sale thats on my formula now, will sell spacers and lug nuts with no tires for 225 plus shipping center caps included they are not curbed up or anythng they could just use a cleaning the car has been sitting in the drive way and we have had tons of rain up here, im located in east tenn. if interested
The Summit and Jegs wheels are nearly the same weight as Welds! If they're not it's by only a pound or so a wheel, I don't see why people think they're so much more weight? They're both alunimum with the Weld being a 2 piece and the Summit/Jegs 1 piece. The only thing I can think of that would make the Weld lighter is the physical size 3.5" vs. 4" Summit/Jegs. Either wheel will be much lighter than you 16X8!
I'm not going to get into a mathmatical argument because I suck at math and even if you expalined how you got the numbers you just threw out I probably wouldn't understand. The OP asked what backspacing and lug size he needed, he got the anwser and our opinions on brands. I'll buy the 15X3.5 is somewhat lighter than the larger wheel. I don't understand how you figure forward rotating mass on a centered, balanced axis (wheel spinning on car) is making the wheel heavier (gravity wise), you expalined rotating mass as we would look at it in terms of a rotating engine assembly. What rpm did you use to figure this rotating weight, wouldn't the weight increase with rpm? i.e. the faster it spins the heavier it seems but only to the center axis, the physical weight does not change If you would like to expalin I'll try to understand.
P.S. FWIW I don't smoke anything, it's an expensive unhealthy habbit!
