60' help
60' help
I posted this in the auto trans section with no response, so I thought I'd try here. I took my car to the track friday night for the first time this year, beginning to tune for the cam. It's mild, 224/230 .535/.544 110lsa. 84 Monte, raceweight ~3500lbs. 26" MT DR, 3.90 gears, Yank 3400. Trans is a TH350C...DA was around +1200, and the best I could muster was a 1.79. Here's why I'm mad-
Stock ZZ4, 3.42 gears, 2400 converter, same tires- 1.80 60' (Great DA)
Same as above, change converter to Yank 3400- 1.79 60' (Decent DA)
Same motor, put 3.90 gears in- 1.76 60' (great DA)
Also, no matter how I launch it the converter flashes to 3000...feels a little lazy then starts pulling. Any ideas? Not enough power for the converter? Too big/small? I'm really frustrated.
It is an RPM Air-Gap. Timing was at 35 total, took it down to 32 and picked up a tenth and 1 mph. The only suspension mod is lakewood anti-hop bars. Haha I know they aren't that bad, but I'm just wondering why I didn't get a better 60' after the cam install. I was hoping for low 70's.
buddy of mine had a 80's monte, could never hook it at the track. Are you spinning the tires? Are you getting good weight transfer?
I used to tell him to take that big *** front swaybar off but he would never listen, LOL
Any video?
Any video?
Not spinning at all, do you think a little more air pressure would help? I don't think going lower would do any good. I believe its getting a good transfer, the anti-hop bars don't let the rear squat; it sits up nice and stays there the whole run. Man the way these cars handle, taking off the swaybar could be a death sentence I don't have any video of it, but I might go to Atco tonight so if a buddy comes along I'll have him tape it and I'll post it up.
If your not spinning, than your suspension/tire setup is working. If you dead hook and it feels a little lazy then picks up, your converter might not be loose enough.
If you are only flashing to 3000 then I think that is the culprit right there. A good 60' will happen when you effectively use your powerband off the line.
I hear ya, I always try to avoid spending money on a build twice for the same thing.
Your other option may be to follow one of the main rules in a drag buid: Drop weight, ex. lightweight racing seats, lightweight drag wheels, !back seats, !spare and jack, etc.
I plan on doing the above things as well, because I don't really want to change my setup much. Also, a lot of people take off the front sway bar at the track only, then put it back before the drive home. That could be another 15lbs right there.
