Drag Racing Tech
How Do I Get My MPH Up?
Old 05-24-2009, 11:06 PM
TORCHD 02 TA's Avatar
Question How Do I Get My MPH Up?
in 10/2007 with my cam only car, slipping stock LS6 clutch i ran a 13.1 @113.
Today same car same set up only now i have a Tgextralia Z grip and i ran a 12.5 @ 116.... I was hoping to trap at 118..
I only gained 3mph How do i gain more MPH?
Old 05-24-2009, 11:28 PM
5.3LJimmy's Avatar
MPH is directly affected by 2 things: horsepower and raceweight. If you want more MPH you have to increase power or decrease weight. I would think 116-118 MPH is about right at your power level. What does your car weigh?
Old 05-24-2009, 11:46 PM
I have no idea what my car weighs.
It is a non dd weekend car. full leather interior, stock radio, spar tire and jack still in the car. And today i had 1/2 tank of gas. Driver weighs 200 lbs
Car is an '02 Trans Am
can you go off that info
Old 05-25-2009, 12:56 AM
dlove's Avatar
3. aerodynamics
4. rotating weight
Old 05-25-2009, 01:35 AM
TA1364's Avatar
5. shift faster
Old 05-25-2009, 10:46 AM
Originally Posted by TA1364
5. shift faster
I really don't think i could shift any faster. I shifter to hard and fast on my last run that i brok my shift ****. And now i think the base on my shifter feels funny
Old 05-25-2009, 12:44 PM
TA1364's Avatar
What rpm are you shifting at?
Old 05-25-2009, 01:11 PM
camscam02's Avatar
shifting hard and shifting fast are two completely different things. just cuz you pull or push the shift **** hard doesnt mean you are shifting fast.
but take some weight out of it, and was the DA?
Old 05-25-2009, 02:05 PM
Internet Mechanic
BlackScreaminMachine's Avatar
6. Air Quality
i.e. Density Altitude (DA)
Old 05-25-2009, 02:13 PM
BADD SS's Avatar
7. Rolling resistance slicks vs. radials
8. Why the hell are we doing numbers???
9. Want to go faster, get some mods.... Like tires, 12.5 @ 116 is horrible... What was your 60'?
116 is a fine trap for a cam only, stock weight car.
You might want to drop some weight, and see what happens.. and give us your 60's..
I am running 125mph traps @ 418 rwhp... losing weight helps alot. I should actually be in the 127-128 range next time out, dropped another 200+ lbs last month....
Old 05-25-2009, 03:19 PM
well i was shifting at 6500, but i know our stock tach is slow. I crossed the traps at the VERY VERY VERY end of 3rd gear. As i crossed i hit the limiter and my needle was at 7k
so i think i need to shift before 7k????
Old 05-25-2009, 03:20 PM
I was more powershidting that speed shifting. I do not like to speed shift. You mis a gear and your banging the rev limiter and i do not like that..
No idea what the DA, i know it was positive though
Old 05-25-2009, 04:17 PM
BAKED's Avatar
Spray it.
Old 05-25-2009, 04:19 PM
TA1364's Avatar
Well if you shift 4th you wont be as high in the power band going across the finish unless you have gears. Was your cutout open? Are the wheels you have heavier than the ones last time you went to the track?
Honestly I think 116 is pretty good for a full weight car and average DA day.
Old 05-25-2009, 04:31 PM
Originally Posted by BAKED
Spray it.
No thanks.....
Old 05-25-2009, 04:34 PM
That is why i did not shift. Yes my cut out was open. When i ran my 13.1 @ 113 it was with stock 5 star chrome 16x8 rims khumo tires (245/50/16). The rims that i ran with yesterday are TTMs 17x10.5 with Nitto Extremes (315/35/17)
So i dunno what the weights are, but i would say the TTMs are hevier for sure
Old 05-25-2009, 05:09 PM
RacerXLs1's Avatar
Where you at 41 yesterday?? IF so you spun decent in first.. Some dr's would help forsure you have a nice car man.
Old 05-25-2009, 05:18 PM
Yup i was at 41 yesterday. I know on my second run i spun 1st pretty good That pass was a 12.55 @ 115.66. My 3rd and final run, i did the same technique at the 2nd run but this run i turned a 12.52 @ 116.35
Old 05-25-2009, 07:30 PM
xpndbl3's Avatar
put some slicks on it if you want to hook. Disconnect the front sway bar at the track will help a bit as will removing dead weight like jacks and spare tires.
Old 05-25-2009, 08:50 PM
tee-boy's Avatar
you won't get your mph up unless something like pressure, temp change. Ain't got much control over mph except not letting off.
