Drag Racing Tech
Frame Horns (!bumper support)
Old 05-26-2009, 09:14 AM
landonew's Avatar
Default Frame Horns (!bumper support)
Anyone have any pictures of how much frame they removed with the frame horns? I don't want to have to weld in the radiator support.
Also, Does an angle grinder get the job done?
Thanks
Old 05-26-2009, 10:43 AM
DMH Fabrication's Avatar
Mine are cut right behind the bumper support brackets and they weighed about 5# for the pair. Angle grinder works. I used a sawzall and then cleaned the frame up with a grinder and welded a thin plate back to the frame to cap it.
Old 05-26-2009, 07:43 PM
Taubr Unit's Avatar
i also used a sawzall and cleaned it up with a angle grinder. Click the link in my sig for pics
Old 05-26-2009, 09:17 PM
BlackWS666's Avatar
I cut as much off as possible. Cant remember the exact weight. But was more than i thought it would be. Hope it helps you out.
Attached Thumbnails Frame Horns (!bumper support)-038-1.jpg   Frame Horns (!bumper support)-039-1.jpg
Old 05-27-2009, 09:03 AM
BigKap94z's Avatar
I just finally did this mod this weekend, i cut back far enough to get the horns, but not so far i needed any core support welding or mods. The horns themselfs weight about 7.5lbs for the pair.
Old 05-27-2009, 11:42 AM
3rdgen92maro's Avatar
I just used a 4" grinder with a cut off wheel to do the job. Heres a few pics of how i did mine.
Old 05-27-2009, 09:06 PM
studderin's Avatar
I have mine, But I saw I think it was SUX2BU lopped off the front. The looks light on the top cut a angle them back about another 4-5inchs. The down the outside of the back. Might need a plasma cutter or some cmall cutoff wheels. it it was a bunch more metal.
Attached Thumbnails Frame Horns (!bumper support)-101_0792-600x449.jpg   Frame Horns (!bumper support)-dsc02704.jpg   Frame Horns (!bumper support)-lightweight021.jpg
Old 05-27-2009, 09:38 PM
Duffster's Avatar
More pics
Quick Reply: Frame Horns (!bumper support)
