Short belt problems :(
I posted a similar thread in the external section...but no solid response...ok I have eliminated my power steering and I have an ASP crank pulley and the asp alt pulley on the car as well...does anyone know what size belt I need? and also if they could explain or show me a pic of how to route the belt for the bypass?...I did it a long time ago and lost 5 tenth's and 3 mph!! felt like my fuel pump was dying..stuck the stock belt back on and ran 5 tenth's quicker and 3mph faster lol...computer compinsation? i dont know...but i am willing to try it again...if ANYONE has bypassed their power steering and have either both asp pullies or just the crank pulley..please tell me your belt size Thank's,
Carter
Carter
I'm not sure, but 51" comes to mind. Bypasssing the power steering can't make you lose any power, something else must have been going on. All you do it look at the stock belt, then route it the same way without going over the power steering pump. You will have to grind/remove an alternator bolt also, I believe.
Awesome..Thank's alot guy's..i wish i could go to the store and try a bunch of different belt's...but i dont have a belt on the car because there is no pump on the car anymore....does anyone know if it's ok to remove the alt bolt?..i did that before and it freaked me out a little..i think that might have been the problem on the track also..could have been tweaking the alt sideways and loosening the belt because the tensioner couldnt keep anough preassure?...oh well i will figure something out...thank's again guy's,
Carter
Carter
Originally Posted by jswhite
With the ASP pulley and stock alt. pulley I use a 505K6. I had a 525K6 on it but it would start to come off. It may work for you since to have the alt pulley.
I got a 510K6 today...hopefully that works..if not atleast im in the right area now...thank's guy's for all the help
Carter
