Drag Racing Tech
What pinion angle works best for you?
Old 08-17-2009, 12:46 AM
pooker's Avatar
Default What pinion angle works best for you?
Do you guys just "play" with it, or is their a preferred angle you use for track?
The reason I am asking is because I have played with adjusting mine alot, and everytime I adjust it , I either get tons of wheel hop, or sideways wheel spins.
Also please post the method you use to measure your pinion angle, since their seems to be a few methods out their. I use the one posted on BMR's site.
Old 08-17-2009, 06:42 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Some more info about the car would be helpful too.
Suspenion Mods?
Tranmission?
Gearing?
Power?
Race Weight?
Tire Combo?
As for the track having more (-) Negative pinion angle helps with the bite, it is something you do not run on the street, and it can damage stuff but it does help as well for 1/4 stuff. BUT every car is different.
Old 08-17-2009, 06:57 AM
omcar's Avatar
I run -2.5 and I drive to and from the track..no problem.
Old 08-17-2009, 08:27 AM
Internet Mechanic
Just an FYI, I reguarly see TQ arm cars who ran a track specific tune to the set up put 5-6 degrees of negative pinion angle. But thats not an angle you want to drive on the street.
Old 08-17-2009, 10:14 AM
tomcowle's Avatar
check your shocks
Old 08-17-2009, 11:13 AM
Race your car!
JL ws-6's Avatar
Anyone doing that with a tq arm car has no clue WTF they are doing.
That's for old school leaf spring cars that have to deal with axle wrap.
I run mine at pretty much 0 to -.5, more you add to the car the more mechanical bind you add to the driveline... which is never good.
Old 08-17-2009, 12:10 PM
Internet Mechanic
And that could be the case, like I said, that is what I have seen. I personally run -2. You are correct on the mechanical bind either way as some people have had their cars incorrectly done and had (+) positive angle and thought it was negative.
Old 08-17-2009, 12:26 PM
tals7's Avatar
Smile
-1 works good for my 4l85e/ls7 combo.on dr,s. -5/-6 stupid.
Old 08-17-2009, 06:52 PM
pooker's Avatar
Well tell me what you guys think. I have a 98 convertible 6 speed spec stage 3 clutch, billet flywheel, umi tunnel mount torque arm, umi subframe connectors, grotti hahn 1 7/8th lt's, slp dual duals, whisper lid and a pro 5.0.
Car spun and got sideways at the track, and I know the worn tires are not helping , but I cannot afford dr's right now so I figured I would play with the pinion angle.
Old 08-17-2009, 09:58 PM
5.3LJimmy's Avatar
Man the pinion angle is not gonna get a car with worn tires to hook no matter what you set it on. You could try a 2x4 under the gas pedal?
Old 08-18-2009, 12:41 AM
35th SS's Avatar
-2 here on both cars even though we still dont have a track.just a weekend warriors for now.
Old 08-18-2009, 01:13 AM
9sec93's Avatar
pinion angle has nothing to do with traction. the only way it may affect your times is if it is binding. change the pinion angle all you want but that is not going to change your suspension mounting points. if you have rubber or poly bushings, you will want a little more negative pinion angle because the bushings will have some give so under a load your driveline will be somewhat straight. if you have all rod ended solid suspension, you dont need as much negative pinion since the rod ends do not give. the main reason for setting pinion angle is so you do not destry u-joints.
Old 08-18-2009, 05:03 AM
daniel6718's Avatar
like said above pinion angle does nothing for traction
Quick Reply: What pinion angle works best for you?
