Drag Racing Tech
Rear drag shocks
Old 09-09-2009, 09:38 PM
89camaro's Avatar
Default Rear drag shocks
http://www.speedinc.com/cont.cfm?cid=C0000233 any one use these or heard anything about them?
Old 09-09-2009, 10:12 PM
SuperSlow02's Avatar
people like um for the price, and i think you can get them cheaper out of jegs directly
Old 09-09-2009, 10:15 PM
89camaro's Avatar
ill have to check it out im sure they would hook better then the stockers?
Old 09-09-2009, 10:16 PM
waterbug1999's Avatar
I have them on mine.. So far so good, not bad for the money.
Old 09-09-2009, 10:24 PM
89camaro's Avatar
what kinda tires are you running on the rear? do you still have the stock springs???
Old 09-09-2009, 10:32 PM
The track picture below is with my 26" ET street with a blown out shock so I upgraded to the competion eng. ones in your link..
On the street I am running a 315/35/17 hoosier drag radial with the car lowered 1".
Old 09-10-2009, 12:15 AM
89camaro's Avatar
were is the adjuster on the shock i looked at some pics and cant find were you adjust it at? is it easy to change the settings while its on the car?
Old 09-10-2009, 12:19 AM
Its kind of a pain.. If I remember correctly, you have to compress it and turn a little washer type deal on it... I just set it on the stiffest and left it.
Old 09-10-2009, 12:36 AM
89camaro's Avatar
dont you want it on one of the softer settings for drag racing?
Old 09-10-2009, 01:53 AM
I started on the stiffest and tried it out... It worked and had no issues hooking so i left it.
Old 09-10-2009, 07:00 AM
tomcowle's Avatar
no, your trying to control wheel movement
Old 09-10-2009, 07:21 AM
night ryder's Avatar
depends on the wheels you are using. i have my qa1s set at 3 and 5 because i have a low profile DR. since i do not have the side wall that a 28" tire has i need to soften the suspension to absorb some of the initial hit so it does not spin the tires.
Old 09-10-2009, 08:49 AM
a98ws6's Avatar
I've read there is a Summit shock that is just a rebadged Comp Engineering shock, just cheaper. Anybody know the part number?
Old 09-10-2009, 09:05 AM
ndfrsd6's Avatar
i have the comp drag shocks and go 1.40 60ft right off the truck ! there a great shock for the money !
Old 09-10-2009, 09:50 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Awesome super budget shock. Have a few cars who have gone 1.35-1.40 60's with them. They are easy to adjust too all you to do is compress the shock and twist the body. There are 3 adjustments on them 90/10, 70/30, and 50/50. I mormally throw them in there on the 50/50 to start with and go from there.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 09-10-2009, 11:22 AM
tomcowle's Avatar
Summits are not rebadged CE's, but they do work great and for 26bux you can't go wrong
Old 09-10-2009, 11:34 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I had those CE 3-position shocks in the white Camaro set at 50/50, 1.38's. I like QA1's since you have 12 settings since I've occasionally changed them from 6/6 to 7/7 for a better track but the CE's are okay.
Old 09-10-2009, 12:00 PM
fastGBcamaro's Avatar
I think a lot of people look past the stock shocks. Not that these aren't good, and having some adjustability is a plus, but if everyone says that for the money they are a good shock. I have gone 1.3's on the stock shocks and springs, and have seen several other members do the same. I think too many people just change out the shocks, when there are other suspension components that are more important IMO. Now if your trying to get a sub 10 second car to hook on a drag radial, then having an adjustable shock is a must.
Old 09-15-2009, 01:41 PM
airforcemanss's Avatar
what are some of the settings you guys are running on the street when you take her out on the wkends?
Old 09-15-2009, 02:10 PM
gyrene2003's Avatar
So is 50/50 the harder set up? With a stock spring and a low profile drag radial would I want to use the softer setting?
