Drag Racing Tech
wheel studs
Old 10-06-2009, 09:11 AM
dreamls1's Avatar
Default wheel studs
Alright, i have 5/8 wheel studs on my 9". Anyone know if the summit stars will fit the 5/8 or will i have to drill them out a little bit.
Old 10-06-2009, 09:14 AM
Race your car!
JL ws-6's Avatar
Any rim designed for a shank style lug nut should work, all the shank style lug nuts are 5/8 diameter.
It might be tight, depending on the wheel, some are tighter on the 5/8 studs then others.
Old 10-06-2009, 09:27 AM
dreamls1's Avatar
well here is the thing, the part of the stud thats threaded goes in the wheel fine but the shank part in the middle doesnt fit in the wheel! Am i doing somthing wrong? If i put the wheels on then the studs in it would work haha
Old 10-06-2009, 11:07 AM
Race your car!
JL ws-6's Avatar
That's where they're usually really tight. I had to take a sanding drum on my dremel to get my bogarts to slide on, and they're still tight (on purpose)
They should be tight on there, that's one key part to keeping it strong (no slack)
Old 10-06-2009, 12:42 PM
dreamls1's Avatar
There is no way of them to fit without drilling (my guess), the holes in the wheels like like 9/16. The threaded side bearly fits let alone the center shank.
Old 10-06-2009, 12:53 PM
Race your car!
JL ws-6's Avatar
Huh... welp I learned something today, at least about that wheel.
Old 10-06-2009, 01:35 PM
dreamls1's Avatar
Well everyone said it will fit, and it will be really tight, just bang them on. I guess i will give it a try
Old 10-06-2009, 07:44 PM
Camaro396's Avatar
Arn't those an acorn style wheel? Like a 60 degree conical seat?
You need a shank style lug nut/wheel.
You bought wanna be drag wheels, I don't think you can get a 5/8 acorn lug.
Old 10-06-2009, 09:36 PM
1BADAIR's Avatar
thats what I was gonna say
Old 10-06-2009, 10:10 PM
dreamls1's Avatar
They are drag wheels, why are they acorn. So am I screwed?
Old 10-06-2009, 11:27 PM
1BADAIR's Avatar
5/8s don't use a shank. they are just nuts
Old 10-06-2009, 11:29 PM
SJM Manufacturing Inc's Avatar
As you cross posted, I answered your questions (and for others who have the same questions) here> https://ls1tech.com/forums/wheels-ti...eel-studs.html
The wheels you have are NOT drag wheels, they are street wheels using tapered lugs. I as well as others have posted regarding those knockoff wheels with rebellion from the potential or current customers.
They are about as much of a drag wheel as my 15" Toyota truck wheels. You have 15" wheels that are heavy cast copies of weld racing drag wheels.
They offer little performance in comparison to a true drag wheel.
