Drag Racing Tech
M&H racemaster or Hoosier QTP dot slicks
Old 10-13-2009, 08:29 PM
RARON455's Avatar
Default M&H racemaster or Hoosier QTP dot slicks
I am ready to buy my tires, but still hung up on which ones, I have had some great advice, (THANKS JASON) I am wanting to stay with a 27" tire, I just had the car dynoed, 463HP 428tq and I will be leaving on a 150 shot in a heavy 6-speed car with a 3.75 gear ratio. I think the car would spin on a "26and I am not cutting my bumper cover to fit a 28". I am stuck between the hoosier -QTP dot slicks 27x11.5x15- and the -M&H racemaster 27x9x15- full slicks, because they come in a size that I think would be perfect. they will be going on my convo pros. I have heard alot of guys say that the hoosier qtp tires will not hook like a full drag slick. I am wanting to get the best out of my car at the track, but I have not really heard to much about the M&H so please chime in, I KNOW THAT alot of guys say run a stiff wall slick on the 6speed car...Im reading help me out I am going to buy tires within the next few days.
Old 10-13-2009, 08:35 PM
Ph.D. in HUBRIS
custm2500's Avatar
I have heard lots of good things about the H and M tires. Hoosier is proven! I would think the full slick would offer similar traction in the narrower tire. From hearing people online in many places I say the H&M.
Old 10-13-2009, 10:35 PM
transam69230's Avatar
You can fit a 28inch tall tire in the wheel well without trimming the bumper. You need to have adjustable control arms, and do the BFH mod and cut the bumpstops off. They will fit without trimming the bumper.
Old 10-14-2009, 01:10 AM
ramairws6's Avatar
You are correct but the bumpstops can stay also. I run the M&H's 28' drag radials and love them! Nice tire all around. I have a set I will be selling soon if anyone is interested?
Old 10-14-2009, 02:25 AM
blu byu EH's Avatar
I second that.
Old 10-14-2009, 08:47 AM
RARON455's Avatar
The only thing is this, The tires are gonna be 400$, I dont want to drop another 200+ bucks on some adustable LCAs when I have the Tubular ones, from BMR. As It sits now with the LCA brackets I welded in, my wheel sits centered in the well. With the 28 inch tire, I am not sure if that would be too much tire for my 3.75 gear ratio, that was the main reason I was leanin on the 27 inch. I would love to run the 26 but have heard alot of guys say that was not enough tire.
But If I am hearing right there are some guys out here with the M&H Slick that are working well.?
Old 10-14-2009, 09:12 AM
Race your car!
JL ws-6's Avatar
28x9 et drag is a 27.3 inch tall tire, and will fit with no cutting or rubbing, I've had them on several cars and they fit. 27x10.5 or 11.5 qtp fit without any cutting/rubbing, the 28's, when they grow, there was no way my 20x10.5S et drag was going to clear that needed to have the bumper trimmed a little, very little, but a little.
Overall, I think, that the 28x9 ET drag, or the qtp, or the given m&h will work. Honestly, it's going to come down to preferance in alot of cases. Some people just have better luck with some tires then others do.
Biggest thing I think you can fit, is a 27x11.5 qtp. That's a decent tire, I've gone bottom 1.5x on them when I ran my car on motor, I think now knowing what I do 1.4x would be possible on them, at the time I was running them I had just started racing my sled, now having everything set right and knowing what to do when the car isn't right, I could get them to work. The 28x9 et drag, IMO works better then a 26x10 does, but it's not the 28x10.5S tire. The S tire has been the best tire I have put on the car to date.
Old 10-14-2009, 06:34 PM
mike c.'s Avatar
I cut low 1.4 60's on M&H Tires in a 3,700lbs 6 speed car. I tried m/t's and,hoosier. The M&h is the only tire I will run now.
Old 10-15-2009, 06:49 PM
03 BUSA's Avatar
We are cutting consistent 1.430 60's with m6 and heavy 3500lb car with the wheels up in 1st and 2nd gear on a set of M & H 27 full race slicks with tubes. Just be sure to use rim screws with the tubes my wheels are spinning 2-3 " per pass and we need to keep swapping from side to side to accomadate this until I get the wheels drilled.
Old 10-15-2009, 10:41 PM
RARON455's Avatar
made up my mind, and bought the M&H racemaster full slick, 27x9x15, after talking with John from M&H he sold me on them. gonna run them with no tubes or screws first and see if I might be able to get away with it.
Old 10-17-2009, 04:44 PM
mike c.'s Avatar
Nice choice my good man. I have been trying to push these tires after M/T Tires didn't do well on MY car and the M&H out hooked them on MY car. Yes I caped the my car because someone will say how great the m/t tires are.They may be,just didn't work for me. Goodluck to ya.
Old 10-18-2009, 08:11 AM
ski23's Avatar
Im in the same boat now that my et streets wont get me the 60' I was hoping for. Im currently running 15x10 prostars with 4.11 rear gear on my 01 M6 camaro. I think the 26" tire doesnt have enough tire wrap so Im looking to go 27" tall. Will the M&H 27x9" wide be enough? and will they fit on a 10" rim? DO I want to go with a cheater slick or a full slick?
Who has best prices on these tires?
Old 10-18-2009, 08:16 AM
Ph.D. in HUBRIS
custm2500's Avatar
How wide is the tire you have on now? The 27-9-15 will fit but ideally should be on a 8 or 9 inch wheel. Depending on your current size you might be giving up some traction because the wheel might be too wide.
Old 10-18-2009, 08:33 AM
ski23's Avatar
Im running 15x10 prostars with a 26x11.5 Et street. 1.6x 60' times are descent but, looking for more. Its a mid to high 11 second car
Old 10-18-2009, 03:31 PM
03 BUSA's Avatar
Why not the 27 x 10?
Old 10-21-2009, 10:37 AM
RARON455's Avatar
Default Who to get them from
Pm me if you want to know where I got the M&H slicks from his price was the same as summit, just a little bit more on shipping but well worth it, super guy to talk to, and a racer, will give you a ton of advice and gave me his number to call him with any questions on the track. Support a Real guy trying to make a living, and buy from him. I dont think I can post his info because hes not a sponsor, so PM me for it.
Old 10-21-2009, 10:39 AM
RARON455's Avatar
Was a little scared of the 12.3 section width getting into my inner fenders.
Old 10-21-2009, 11:48 AM
03 BUSA's Avatar
I removed my tubes last night and want to try to run the tires tubeless. Everyone I talk to has said to get rid of the tubes from engine tuners to chassis guys??? Guess we'll see.
Old 10-21-2009, 11:49 AM
03 BUSA's Avatar
Mike, are you running tubes??
Old 10-21-2009, 12:28 PM
Ph.D. in HUBRIS
custm2500's Avatar
Everyone I have talked to said take out the tubes. I don't see any real need since they are already there. Almost no weight and I won't be spinning the wheels since I don't make that much power. Any other reason to remove the tubes? Going to the track tonight and the more I hear about it I think I will take the tubes out before I load it up.
Quick Reply: M&H racemaster or Hoosier QTP dot slicks
